another dumb exhaust question
I had a buddy of mine tell me that if you run a 5" straight pipe on an all stock truck(2007 f-250 6.0L psd) that it would run like crap. Is this true I was lead to believe that after the turbo the bigger the better, that you wanted zero back presure.
Stock 6.0's do need some backpressure. Some Straight piped stock 6.0s will set a CEL some wont.
what is a CEL
CEL is a check engine light. sorry about that
oh right i should of caught that. Man i really want that 5" from mbrp but im not doing any mods for awhile( tight Budget).
From what i've heard and read, a 5" will only benifit if your truck is makin' over 500hp. Otherwise, a stock truck won't run quite as well as a 4" exhaust.
yea but if your going to straight pipe it you think 4" or 5" would be pretty close to the same
3.5 to 4 in. is approx. a 15% increase in flow. So 4 to 5 in. would be around 30% increase in flow if my math is right? A stock motor does not need a 30% increase in flow. 4 in. is more than enough. Just get a 6 inch tip that'll fit a 4 inch pipe man.
you could jst straight pipe it with stock tubing
