Power delay
The delay when you nail it to getting the rush is apx 1-3 seconds what can I do to shrten that I already have airraid box, what should I do to spool up quicker? 03 350 duelly
programmer will help a bunch..what engine u got?
Have 6.0 I also did zoodad , Did your exhaust sytem help alot , did you really feel the difference or not really
it sounds alot better..seems to have more top end power but didnt do any noticable improvements on low end.best thing to get good power will be the sct and gauges.u wont be sorry.u can have them write u anything from mild to wild. u should talk with one of the site venders about it and they will answer ur q's
good luck |
one thing that helps is to roll into the throttle slowly and let it start moving before you mash it to the floor. if you just mash the throttle from a dead stop it will get going a lot slower. just give it a little throttle and as it starts going give it more and more.
play with that a little you will find the quickest way to get going. you can also hold the brakes and give it a little throttle to build some boost. not too much or you'll boil the tires practice that see what you think. |
Roll into the throttle. If I pegg it off the line my truck will bog and by the time it takes off I've already lost the race.
How do I contack the sct people -then they build me somthing to install? Like chip or tuner to plug in
You'll hear a few different vendor recommendations here. I have one from DJ Diesel Performance. They have great service and awesome tunes. Vivian will walk you through everything. You can email Vivian at DJ's here: vivian@dj-performance.com
I'm sure other people will recommend some good places too. |
x2 for DJ's!!!
I had the same problem until I got a Xcal3 form DJ's. Not anymore.......And yes, Vivian is the bomb!
