air intake - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-26-2012, 01:15 PM Thread Starter
powerstrokin88's Avatar
air intake
wondering what air intake set up anyone has been running and using on their 6.0's that are any good also wondering if anyone has ever heard anything good or bad about injen technologies air intakes???????
powerstrokin88 is offline
post #2 of 9 Old 12-26-2012, 02:31 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yeah, I hear they're expensive I run an Airaid
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #3 of 9 Old 12-26-2012, 02:37 PM
ktyamaha36's Avatar
Most will tell you to keep the stock intake. It flows MORE than enough air, and traps dirt much better.
I still have my stocker. But when I find a good deal I will be buying a S&B intake. It wont do much for performance, but it will make filters easier to change and let the turbo sing a little louder to me!
2005 6.0 CC SWB 4x4
EGR Delete
4" MBRP Turboback Exhaust, No Cat, No Muffler
S&B Intake
SCT Tuned by IDP & Vivian
Sinister Coolant bypass filter
Updated STC Fitting
Blue Spring upgrade
EDGE CTS
9" Lift,
PMF Long arm 4-link kit
Pro Comp Traction Bars
Dual Steering stabilizers
Dual Fox Resi's in the front
20x12 Moto Metal MO962 wheels
38" toyo's
ktyamaha36 is offline
post #4 of 9 Old 12-26-2012, 02:38 PM
Dirty_Stroke's Avatar
Idk about Injen intakes but I run a S&B on mine and like it. I noticed a difference in initial take off power and throttle response.
05 F250 FX4 Lariat, SCT Livewire, 155cc injectors, Gryphon FICM tuner, ARP studs, MTW Stage 2 Turbo, Riff Raff boots, Warren Built trans, PMF traction bars ,4 inch straight pipe, Sinister EGR delete, S&B CAI, N-fab bars, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked everything, Harley headlights, 5k HID's, Camlocker toolbox, lots more
Dirty_Stroke is offline
post #5 of 9 Old 12-26-2012, 03:13 PM
Factory box, Airaid filter, Zoodad mod (hole in fiberglas in front of box), 6 years, $75, no issues.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 9 Old 12-26-2012, 08:02 PM
kcoyner's Avatar
Quoted: 57 Post(s)
I'm running the Banks. I bought it off of a wrecked truck and got a helluva deal on it. It was only a couple of months old when the truck was totaled. I would buy it again. If for no other reason, it comes off like a well made piece and goes back on the same.
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #7 of 9 Old 12-27-2012, 12:06 AM Thread Starter
yeah karls 03 i have the same thing in my truck came with it when i bought it sucks to get out to clean i still have the front of my air box on, i think it gathers alot more cooler air ???
Only reason was wondering about the Injen technologies set up is i see they are the only ones with a all aluminum intake pipe vs plastic
post #8 of 9 Old 12-27-2012, 10:09 AM
I did the drop in because most of the CAI's that I saw in 2006 replaced the air box with, guess what, ANOTHER BOX! When I took the front cover off I found 2 things, it was easier to take out of the truck (still a PITA, but easier), and that i picked up 1~1.5 mpg in town. That should answer which method pulls more air.
I looked at Injen Technology's CAI, ever thought about using Spectre's DIY CAI kit from your local auto parts store? It wouldn't be aluminum, but it would smooth out the air flow. You could put your OEM MAF sensor in with some epoxy.
Karls03 is offline
post #9 of 9 Old 12-27-2012, 10:46 AM Thread Starter
ill have to pull the front of my cover off and try it the air box's for these 6.0's do suck indeed!!! i never thought of the DIY i will have to look into that
Tags
air cleaner , air filter , air intake , intake
