can i still run cooler egts - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-31-2007, 06:54 PM Thread Starter
bunch85e's Avatar
can i get good performance if i keep my stock intake for the 6.0 and just put afe filter in it or would it be better to get afe stage 2 $400 vs $80
bunch85e is offline
post #2 of 10 Old 10-31-2007, 06:55 PM
yes, it would be more cost effective to just get a better fitler, but keep your stock intake, as it is designed pretty well from the factory..
if you haven't already, do the Zoodad mod (cut a hole in the radiator/IC support) and that will help with EGT's also. Both of those changes should get your EGT's somewhat lower
Blue01F250 is offline
post #3 of 10 Old 10-31-2007, 06:59 PM Thread Starter
bunch85e's Avatar
if i do that would it still not be able to run as low egts as i would getin differnt intake
bunch85e is offline
post #4 of 10 Old 11-01-2007, 12:14 AM
DoubleDpsd's Avatar
you will get cooler egt's running an afe rather than the stocker. that's my opinion. I run cooler with my afe than I did with my stocker. again, that's my observation. If you wanna run an afe stage 2, I say go for it!
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #5 of 10 Old 11-01-2007, 12:26 AM
The Fat Mod
Logan's Avatar
Do you have a free flowing exhaust yet? That will help the most.
Logan is offline
post #6 of 10 Old 11-01-2007, 03:03 AM
npccpartsman's Avatar
Quoted: 5 Post(s)
I run a stock intake and don't have an EGT problem. Unless you're gonna do some major modifications to go over 500rwhp the stocker is fine. Save your money and use it on a good exhaust or something more worthwhile.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #7 of 10 Old 11-01-2007, 03:54 AM
Rob
Rob's Avatar
Quoted: 2 Post(s)
Start with the exhaust, see where it is at, the go from there...
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #8 of 10 Old 11-01-2007, 07:11 AM
Slacker
Evil Eye's Avatar
Quoted: 190 Post(s)
Feedback Score: 4 reviews
Oh, and the stock air filter is manufactured by Donaldson, so it's a really good filter. The airbox design isn't bad, but there are others that flow much better. I'd agree that you should be fine with your stock airbox.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 10 Old 11-01-2007, 06:00 PM Thread Starter
bunch85e's Avatar
whats everyone one useing as a replacement filter afe or that true foam volvant air intake
bunch85e is offline
post #10 of 10 Old 11-01-2007, 06:14 PM Thread Starter
bunch85e's Avatar
ya i know agergergerh
2006 F-250 extd cab short bed 6.0 POWERSTROKE
xcal 3/quadzilla commander with innovative tuned by eric and dj's looney tune
4inch straight piped with 5inch tip
afe stage 2 intake system
LOOKS-----
Diamo Karet 117 machined black 18x10 rims 33/12.50/18 toyo M/T's.
15% window tint all around with 5% eyebrow
Recon Smoked led lights all around with harley headlights.
how about them smokeing powerstrokes!
bunch85e is offline
