how to use ARCHOIL- - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-25-2012, 04:34 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
how to use ARCHOIL-
Im getting ready to switch from dino oil to synthetic and do the Archoil treatment. While reading up on their web site I came across this- "Treat engine with 16oz of AR9100 at any time before an oil change to start the cleaning process immediatley even if you only have 500 mile left before a scheduled change. The balance of the AR9100 will be on hand for the next oil change".
So my question/concern is, when I do the first treatment can I leave it in the truck for 5000 mile or possibley more? Or does it "stir up to much trash and should be flushed fairly soon?
Thanks
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 4 Old 12-25-2012, 04:42 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I have always used synthetic oil since my first oil change on my truck and I have had my truck since new with only 4 miles on it from the dealer so I don't know if this will help or not but when I first switched to Rev-X, I also switched from 15w40 to 5w40 and then added the revx at that time. When I did my next oil change after that, I still used 5w40 but instead of using revx this time, I used Archoil. I guess I said all that to say that I recommend just draining the oil in the truck when it is good and hot (so you get as much out as you can), then put in the synthetic oil and the Archoil and then just keep going with it for all future oil changes. Unless you wanted to get two 16oz bottles of the stuff, I wouldn't add it in with your current oil to just get rid of it when you swap over to synthetic. Hope this helps.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 4 Old 12-25-2012, 04:46 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Thank you it does help. Just wanted to pick over some other's brains in case I over looked or over thought something (wouldnt be the first time Ive done that!!!)
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 4 Old 12-25-2012, 05:33 PM
strokin6L's Avatar
Quoted: 4 Post(s)
I've used Ar9100 and rev-x alot in the last few years. I've always installed it when doing the oil change...even from the first time using the stuff. I've been running a 5w-40 synthetic for nearly 8 years
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
