Sinister Solid Y-Pipe
Anyone used this setup in order to get rid of the stock and prone to crack flex joints? If so, how do you like them and would you recommend them?
Sinister Exhaust Y Pipes Ford Powerstroke Diesel 6 0L 2003 2007 | eBay |
i think its a terrible setup. You need to have bellows in that part of the exhaust due to the vibration. The sinister y-pipe in time will crack. Send your factory y-pipes out to get heavy duty flex joints with them ceramic coated and you now have a bullet proof set-up
I have not seen this before.I have their coolant filter and has been great. Hopefully someone will chime in about this product, it looks to be a great product.
The main reason for the flexjoint is not for vibration. The turbo is mounted to the same thing that moves/vibrates. The reasoning for the flexsection is for the expansion and contraction from the high temperature differences. As the pipes heat up they swell/lengthen and shorten as they cool down. only a fraction of an inch but enough that could damage/crack welds and cause issues at sealing joints.
The bellows aren't that bad of a design. At least we dont have a slip joint manifold that only seals after the engine finally gets hot |
Take a look at the RCD y pipe, that looks like a nice piece.
These look like a slip joint design as well.
Ive got IDP's long Y pipe on my truck. Great fit and finish. |
Where could I get quality stainless sections? I only wanna do this once.
