6.4 Banjo Bolts and Blue Spring? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-22-2012, 07:14 PM Thread Starter
Hey guys i dont post much on here just read around and gather want i can but i have a 2003 6.0 SCT Xcal2 been on the truck since 06 custom tunes from innovative just ordered the livewire ts two days ago. I am not studded or egr, I think im having fuel problems and was wondering what the advantages of having the 6.4 banjo bolts and blue spring mod are?
Core2012 is offline
post #2 of 7 Old 12-22-2012, 07:31 PM
dnf12908's Avatar
Quoted: 24 Post(s)
The blue spring is highly recommended. As for the 6.4 banjos, there are mixed opinions. Do a search and make your own decision.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #3 of 7 Old 12-22-2012, 09:02 PM
kcoyner's Avatar
Quoted: 55 Post(s)
I would do the blue spring whenever you can. The Banjo Bolts are not something I'd wake up on a Saturday morning and go: "Alright, today's the day for new Banjo Bolts". It's more of a thing like "well since I'm into it this far I may as well go ahead and do it.
k
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #4 of 7 Old 12-22-2012, 10:57 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
k
Agreed! Honestly just stick with the ones that were designed for the 6.0, there is no performance gain of adding 6.4 banjo bolts. As said above though, do the blue spring ASAP and monitor the fuel psi. Last thing you want to be doing is replacing injectors because you didn't monitor your fuel psi!
Sent from my iPhone using AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #5 of 7 Old 12-23-2012, 08:23 AM
Term3's Avatar
Just because we can't figure out why something was made a certain way by an engineer is not a reason to "reinvent the wheel". Had a bud that got rid of his banjos but he added his own checkvalves to the tubing.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 7 Old 12-23-2012, 09:24 AM
shawnb99's Avatar
just asked this on the other thread,
did he test for any gains, why go through the trouble and expense when there are no gains to be had when swapping.
again, you will gain nothing by swapping to the 6.4 bolts.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #7 of 7 Old 12-23-2012, 06:17 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
the 6.0 have check valves or something in them where the 6.4 banjos have no check valves and have 4 holes where 6.0 ones have 2 if i remember correctly. its not really a perf gain thing, more of a peace of mind knowing that accompanied by the blue spring update your injectors are getting fed as much fuel as they possibly can with nothing hindering the flow. they take no time to swap out and they are fairly cheap. my two cents
btw, if your having fuel related issues, i wouldnt think the blue spring is gonna fix anything. what makes you think your having fuel issues? do you have a fuel pressure gauge? how old are your fuel filters and are you using motorcraft? just some ideas to throw out there
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
