Part ID help
Can someone tell what this part is and where it goes? It came with my head gasket kit. Thanks, Ray
Its the oil feed tube for the injector oil rails on a 03 engine. Early 04 trucks (built before 9/23/03) have 03 engines in them. If the ICP sensor is not in the passenger side valve cover thats another way you can tell if its an 03 engine.
Thanks I did the stc fitting today and wanted to make sure I didn't miss something before I put the cover back on hpop.Mine is a 2006.
04 and up use a completly different feed tube. You might want to put the updated feed tubes and dummy plugs in the oil rails also to prevent any high pressure oil leaks down the road.
