loctite on arp's and hand tight? does it work - Ford Powerstroke Diesel Forum
Old 12-16-2012, 08:17 AM
For those that have studded their trucks have you or haven't you used loctite to get em to stick into the block and is hand tight really tight enough
Old 12-16-2012, 10:05 AM
Powerstroke Techie
Feedback Score: 8 reviews
correct make sure all oil is out of stud holes! clean them well! hand tighten or use ratchet but just snug them. that is all!
Old 12-16-2012, 01:41 PM
Locktite is a bad idea. The studs only need to be home to provide hold. The clamping force that comes from the nut during torque is more than enough to prevent loosening.
Old 12-16-2012, 01:43 PM
there is a spec for using locktite
call ARP or I think it's on the directions ,, but you don't let it cure IIRC
Old 12-16-2012, 01:47 PM
this will make it easy to figure out
http://arpdiesel.com/Instructions/250-4202.pdf
Old 12-16-2012, 02:07 PM
I use a 5mm hex socket to spin them in, then when they bottom out, I back them off a half turn, then retighten by hand.
Like Juggernaut said, make sure there is no oil in the threaded holes in the block.
If there is, the studs wont bottom out.
I used a plastic syringe with a small piece of vacuum hose on it to suck the oil out.
Old 12-16-2012, 02:17 PM
isn't a compressed air gun the easiest to clean them out ?
Old 12-16-2012, 03:40 PM
ARP specifically states that you can can use loctite or their lube. They don't recommend using both though. One or the other.
You could do that. If someone did that, I'd recommend a lower psi than a typical shop air compressor and to cover the surrounding area with rags. Using compressed air to clean liquid can make a nice nasty mess, really fast!! There are a number of ways to used compressed air to create a vacuum and with a small enough hose, you could vacuum the oil out with success.
Old 12-16-2012, 03:51 PM
Not familiar with the procedure on the 6.0 but I have never used loctite on any other motor, just moly lube.
Old 12-16-2012, 05:33 PM
The note under step #5. I'm not doing it, just showing that ARP offers it as an option.
