Edge EAS - Ford Powerstroke Diesel Forum
Old 12-14-2012, 06:57 PM
Edge EAS
If I get the eas starter kit and the universal 0-5v sensor input can I just cut the plugs off the ends and wire in a 0-5v pressure sensor from ebay. I am trying to avoid paying $135 for every single pressure sensor I want to install when you can get the 0-5v sensors on ebay for like $5. Edge uses to sell adapter harnesses to use your own sensors but they quit that when they came out with there own sensors.
Old 12-15-2012, 12:14 AM
Good question Gary. Can you get the EAS sensor cable without ordering a sensor? I'd like to know too. I would imagine any 0-5v source would work,
Old 12-15-2012, 04:45 AM
Feedback Score: 3 reviews
The only issue I can see is that not all sensors have the same "min/max" volt to "min/max" psi rating. This can give you a false psi reading because the Edge software is pre-programmed with the settings to only match the Edge EAS sensors.
Sent from my iPhone using AutoGuide.com App
