lookin 4 "Big 3 upgrade" pics- - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 25 Old 12-08-2012, 02:28 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Was lookin at the pics in the "engine bay's lets see 'em" thread and noticed the extra cables in one of the post. (big 3 upgrade) Was wondering if anybody has a good diagram or some good pics on this for a "how do". Also is the welding cable that was seen in the pic needed or what would you say minimum sizr should be. Thanks 4 your time! J.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 25 Old 12-08-2012, 02:45 PM
Njstroker91's Avatar
I googled it and couldn't find much for ford but lots of write ups for Chevy. I am definitely interested also.
Sent from my iPhone using AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #3 of 25 Old 12-08-2012, 06:15 PM
scparrish's Avatar
Quoted: 114 Post(s)
Feedback Score: 3 reviews
Also interested
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Stage 2 Turbo, PHP FICM Tuning, PMF, S&B, Mishimoto rad/ic, 08 axle swap 3.73 gearing
scparrish is offline
post #4 of 25 Old 12-08-2012, 06:17 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
It just insures you have adequate grounding and power. The make and model of the vehicle doesn't matter. It's all pretty much the same idea vehicle to vehicle.
The “Big 3” upgrade is a swap or addition to these three cables:
1) Alternator positive cable that runs to the positive terminal of the battery
2) Negative battery cable that runs from the battery to the vehicles chassis
3) Chassis grounding cable that runs to the engine block
Use #1 or welding wire for this job. On our trucks I suggest running one grnd to the engine and one to the frame, then grnd the cab to the engine or the frame.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 25 Old 12-08-2012, 06:28 PM
Thanks Mitch what do think is a good choice 1/0 welding cable or go even bigger with some 2/0 or is that overkill?
post #6 of 25 Old 12-08-2012, 07:55 PM
1/0 is plenty big
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #7 of 25 Old 12-08-2012, 09:19 PM
PGreenSVT's Avatar
What Gary said ^^^
RIP Mitch
the Org crew
post #8 of 25 Old 12-09-2012, 02:21 PM
Does any one have some pics for this mod a little foggy still. Visuals always help
post #9 of 25 Old 12-09-2012, 04:27 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 11 Post(s)
First pic, cable goes from batt positive to alt post. Second pic, batt negative to body, you can see the cable coming from negative post and loops to where i'm pointing. You can forget about frame to motor pic, it's raining out and muddy!!
Stiles likes this.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
The Following User Says Thank You to Lilpooh For This Useful Post:
Stiles (03-05-2014)
post #10 of 25 Old 12-09-2012, 04:36 PM
do you have to run the positive from alt to both batteries or just one ? If just one, which one ?
How bout ground ?
Joe
4realestate is offline
