Turbo Bag - Ford Powerstroke Diesel Forum
Old 12-03-2012, 08:13 AM
Turbo Bag
anyone ever used a "Turbo Bag" or what ive seen them called. its basically a "wrap" for a turbo. always saw them and heard good things in the Subaru world when i had my STI because of quicker spool and cooler under hood temps. any thoughts about this and wrapping the downpipe?
Old 12-03-2012, 08:17 AM
turbo blanket, I have run them in cars in the past.
100% helps with underhood temps.
Wrapping the DP is good, it keeps it hotter. The hotter it is the faster the exhaust gases will flow.
Old 12-03-2012, 08:39 AM
turbo blanket! thank you! i knew i had something wrong there. i figured it cant hurt. im gonna upgrade the downpipe so why not go ahead and wrap it while im at it? then turbo blanket and done.
Old 12-03-2012, 12:26 PM
All the turbo blankets I have seen are for the T3/T4 based turbos. Will they fit out Garrett turbo? If not does anybody make a turbo blanket for the Garrett? I would like to run one.
Old 12-03-2012, 12:48 PM
i might put one on if i decide to do my s366
Old 12-03-2012, 01:18 PM
Like this?
Old 12-03-2012, 01:23 PM
Turbos = Witchcraft
I haven't seen one specifically for the Variable Geometry turbine housing. That doesn't mean you won't find one that works, but the VGT turbine housing is somewhat larger than a lot of T3/T4 housings.
Old 12-03-2012, 01:29 PM
Turbo blanket
Subscribed
Old 12-03-2012, 05:54 PM
Originally Posted by Eric@PTP View Post
Like this?
Right now that's what my only turbo bag looks like. It doesn't hold in the heat and it's getting scorched. Besides, it just looks silly and I'm embarrassed to open my hood.
Old 12-03-2012, 06:47 PM
Like this?
awesome
