just bought my first 6.0 need some help
after being a gm man for yrs i broke down and bought a 2006 f350
1.egr delete 2. coolant flush then switch to cat silicant free extended life coolant 3. custom sct tuning 4. 4 inch exhaust 5. coolant filter 6. head studs how can i tell if the oil cooler is any good? thanks in advance for the help/ |
Read the Stickys in the general section.....check deltas to see if you need an oil cooler. That process should be in a sticky, if not search it.
Number one priority is to get something to monitor all engine vitals such as an Edge Insight or Scan gauge
ok thanks. i didnt check the eot/ect before i bought this is there anyway to tell just by driving it the health of the oil cooler ? or do i need to just read it with a scan tool ?
Gotta have something to watch it. A scan tool won't do it
You need a scan tool.
Gonna have to be a high dollar scan tool. Insight or Scangauge is the way to go.
A monitor solution is first.
Write Up: Monitoring the 6.0L PSD. Check your ECT/EOT delta, FICMv, Fuel psi for initial health and direction that you may have to go with issues being fixed. Then if you need to dig into the motor to fix any issue you find, replace any of the OEM parts that could cause issues down the road like STC fitting, dummy plugs, stand pipes, fuel psi spring. Here is some info about STC fittings and other OEM upgraded parts. Write Up: Bullet-Proofing the 6.0L PSD. Sent from my iPhone using AutoGuide.com App |
The first pic below you see a "yellow X", that is what a aftermarket EGR delete looks like. But there are DIY welded EGR coolers also. The second pic is what the ARP head stud look like when compared to the OEM head bolts, I'm holding the OEM bolt.
![]() ![]() Sent from my iPhone using AutoGuide.com App |
would a ford dealership have something capable of monitoring these? |
