i think i'm having boost issues - Ford Powerstroke Diesel Forum
Old 11-24-2012, 04:15 PM
I am running quick trick's looney tune, and only seeing about 20-25psi of boost. Is this normal, or do I have other trouble?
Old 11-24-2012, 04:20 PM
Stud tune or stock stud tune? Depends on the load also
Old 11-24-2012, 04:36 PM
I am non studded, no load psi.
Old 11-24-2012, 04:37 PM
But my other 6.0 would hit 30 psi on the canned stc tune, thats the only reason I am wondering.
Old 11-24-2012, 05:21 PM
Did it ever hit more than 20-25? Check your map hose going into the intake manifold for cracks or anything
Old 11-24-2012, 06:18 PM
Where are you reading boost from? If you are reading through the obd2 port it will be low, most tunes have a boost foolers to keep the ecm from opening the vanes of the turbo for over boost.
If you are reading from a mechanical gauge then you may have a boost leak somewhere, check all your boots for rips or cracks. It should be pretty obvious it you have a leak somewhere.
Old 11-25-2012, 10:26 AM
What does the MAP hose look like? And where abouts is it located?
Old 11-25-2012, 10:38 AM
passenger side intake manifold rubber hose just behind the alternator leading up to the fire wall above the condeser unit.
Old 11-25-2012, 11:03 AM
Alright, I checked map hose, and everything seems to be ok. Could it possibly be a map sensor?
Old 11-25-2012, 11:16 AM
How are you reading boost?
