How to get MBRP exhaust pipes apart??? - Ford Powerstroke Diesel Forum
Old 11-24-2012, 09:13 AM
I have an MBRP 4" exhaust on my 6.0. After about 3 months of driving it, i opened the hood to check on things and i found a gap in between the down pipe and turbo outlet. So i decided to loosen the clamp and try to straighten it up, and now i cant get it back on at all! So ive taken all of the exhaust clamps off and im trying to seperate the pipes so that i can position the down pipe correctly. Has anyone else had to do this? Are there any easy ways to seperate the pipes? Thanks in advance.
Old 11-24-2012, 09:22 AM
They make an exhaust pipe seperater,forgot where i saw it.
Old 11-24-2012, 10:01 AM
I would try penetrating oil and a dead blow hammer.
Old 11-24-2012, 10:58 AM
I was jiggling the pipe aound until it moved into position. I dont think its perfect, but itll do! Thank you.
Old 11-24-2012, 06:24 PM
I'm gonna buy new down pipe and 5 inch pipe and redo my exhaust with band clamps instead of the junk normal clamps that came on my mbrp as I now can't get mine apart do to crimped connections
Old 11-25-2012, 10:36 AM
Never use those crappy u-bolt clamps. You'll never get the pipes apart again. I always use band clamps. Costs a little more but there is no problem getting them apart. Especially if you use anti seize putting them together. Band clamps FTW.
Old 11-26-2012, 11:59 AM
My exhaust had 4 relief cuts in it to aid in clamping. A flat screw driver and hammer were enough to lift up the union to get it apart.
Tags
6.0, exhaust
