Got my gauges! - Ford Powerstroke Diesel Forum
Old 10-26-2007, 03:09 PM
Send a message via AIM to spardigus Send a message via MSN to spardigus
Got my gauges!
So i finally got my gauges in and I am havin some trouble. For starters the boost gauge has a clear line with a T on the end that is supposed to tap into a hose somewhere. The instructions arent too clear so I dont know where it is and second is it gonna be safe. It seems to me that it might get blown off to easy. I have seen people tap directly into the turbo pipe but I would rather not do that just cause the hole wasnt on the truck when I bought it. Also the trans temp isnt too clear on exactly what I am supposed to do either so any help would be greatly appreciated.
Old 10-26-2007, 03:24 PM
The Fat Mod
The T goes into the MAP line. Just cut it, and insert. you can put a couple of small hose claps on there if it seems loose.
The tranny line will go into the test port on the driver's side I believe. I am trying to remember if it is in the same loaction as the 5R110s. or not.
What year is your truck?
Old 10-26-2007, 03:26 PM
It is an earlly 03
Old 10-26-2007, 03:37 PM
The Fat Mod
Oh ok, duh huh...If I looked at what section this was in. Yeah, there is a test port on the driver's side of the tranny, it just looks like a little bolt, I think it is an 8mm. Not sure though. Take it out, and put the probe in.
Old 10-26-2007, 03:39 PM
The Fat Mod
Here, look through this, and yo uwill come to the the tranny section, it has some good pics.
http://www.quadzillapower.com/downlo...nder_main2.pdf
Old 10-26-2007, 03:54 PM
I am still new at figurin out things on my motor so if got a picture or a detailed link I would appreciate it.
Old 10-26-2007, 03:55 PM
thats for the map line by the way
