h&s xrt pro.. egr delete really CONFUSED! - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-17-2012, 02:18 PM Thread Starter
ok im gonna make a really long story short..i have a 06 f250 6.0...been having egr insuffecent flow problems since i bought it.. so after several times of back and forth i decided to tell them to get me a tuner and a delete kit.. and i will install the delete kit (didnt trust the garage).. thought they would buy a sct tuner to shut off the egr till i delete it.. well ended up getting a h&s xrt pro..they installed the tuner and the light was off..well got it home today and i was fooling with it.. returned it to stock then reinstalled..none of the times i did this did the tuner prompt to turn off the egr?? did i get screwed again? after i returned it to stock form do i need to disconnect the battery and reconnect to get it back to original? or when the xrt was installed it automatically turned off the egr?....im getting really confussed? and need to know when i delete this that im gonna have to get ANOTHER tuner to turn the CEL off?... can i get it back to true stock??
hillbilly-f250 is offline
post #2 of 17 Old 11-17-2012, 02:21 PM
sargar's Avatar
email H&S and ask them. The only XRT Pro I have installed was on a 6.7 Cummins and I can't remember if it asked me or not.
Sent from my DROID X2 using AutoGuide.Com Free App
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #3 of 17 Old 11-17-2012, 02:38 PM Thread Starter
im thinkin that it asks u and u have to agree to a disclaimer on the xrt.. i just wanna make sure its off b/c i dont wanna egr delete and throw a code then have to wait for a tuner to turn it off.. i should be able to return it to stock and everything should work? right?...wth
post #4 of 17 Old 11-17-2012, 02:51 PM
sargar's Avatar
If you return it to stock it should set an EGR code. That sounds familiar about having to agree to a disclaimer. The H&S that I installed was picked out and bought by the customer after an EGR delete and it was all that was needed to make his code go away forever.
sargar is offline
post #5 of 17 Old 11-17-2012, 04:01 PM Thread Starter
its set at stock oem...i used to be able to use my auto scanner and see if the egr was ok but now the scanner says egr inc? so im not sure whats going on..seems like me if u set it to stock then reinstall the tunes from h&s then the xrt should ask about the egr?..ive installed h&S tunes and stock tuned a couple of times and still the same problem...anyway i can check to see if the egr is working with it set on stock?
post #6 of 17 Old 11-17-2012, 05:30 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
You might not like reading this.
http://www.hsperformance.com/press-release/
Sent from my iPhone using AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #7 of 17 Old 11-17-2012, 06:13 PM Thread Starter
yea i read that..mine was made last month..might have to call them and ask whats goin on with mine...glad i didnt spend the $ on it but i might end up spending for a sct
post #8 of 17 Old 11-18-2012, 03:54 AM
Quoted: 48 Post(s)
you can still buy brand new ones. That's old news.
it does not prompt on the 6.0. It turns it off every time
drunk on diesel is offline
post #9 of 17 Old 11-18-2012, 04:27 AM
Powerstroke Techie
Lilpooh's Avatar
Are you sure?? Looks like H&S just posted this news Nov. 13, 2012.
Lilpooh is offline
post #10 of 17 Old 11-18-2012, 04:56 AM
Quoted: 48 Post(s)
Yes, I'm sure. You can still buy new units. No shipping to California
