Money Pit
So i had a engine failure with a piston smacking a valve amongst other problems from that, so i got a new long block on the way thats bored .20 over-mahle pistons the works through the heads refreshing them with studs i got a powermax and 190s on the way too, i got the 6.4 banjos and doing blue spring mod also im going to go with idp sct tuner with the display for gauges. I am wondering a few things will i need a lift pump and what numbers might i see? truck already had 4in turbo back and intake
what year is it I don't think th 03/04 hpop will handle 190's not sure hopefully someone else will chime in.
Its a 2004
it should be good but you might have to worry about the fuel supply probally up grade it but I would install everything then judge from there. thats pretty much what I wanted to type early was helping someone else out and lost track.
A 03/04 HPOP will handle 190's just fine.
i plan on doing my fuel system i just need to recoup some money and when that is i will probably go with airdog 2 165 i think that will handle what i need for it
Ya I know just got caught up talking to a freind on the phone about his when I typed it guess I can't multi task LOL
It will but I would just put it all togther and just see what it does a WOT test and then plan on spending the coin. forgot to ask are they 190/100 or what
yes they are 190cc/100%
I would defintley plan on it then there was a post about a week ago on this search 190 under the 6.0 preformance i think he went with a airdog and a sump if i remeber right.
