Programer on two trucks.. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-14-2012, 10:51 AM Thread Starter
Looking to buy a programmer for towing. I have 2 trucks. Can I load the upgrade on one truck and use it, then uninstall and use it on other truck when I need to use the other? Or is it VIN specific?
Thanks
JR
TexasFocus18 is offline
post #2 of 11 Old 11-14-2012, 11:02 AM
ZMANN's Avatar
Quoted: 1353 Post(s)
The SCT devises have a limit to how many vehicles it can tune(6 IIRC) so every time you swap between trucks it vinlocks and u loose a use until it's out the reset fee is $150.00 so SCT isn't a choice
We Miss you Ronnie
ZMANN is online now
post #3 of 11 Old 11-14-2012, 11:03 AM
Quoted: 348 Post(s)
Feedback Score: 5 reviews
As far as I know, all tuners are VIN specific... Gotta buy each truck it's own.
As for tuner choice, get SCT tuners ONLY for your 6.0 vehicles
Your tranny will thank you, and your Head Gaskets.
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 11 Old 11-14-2012, 11:15 AM Thread Starter
Thanks guys...
post #5 of 11 Old 11-14-2012, 06:18 PM
smokersteve's Avatar
Quoted: 19 Post(s)
I also have 2 ford trucks. One 06 6.0L and one 11 5.0L.
Coul I tune the 5.0L once, and then keep the SCT on the 6.0L like normal.
So I would use up 2 out of the 6.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #6 of 11 Old 11-14-2012, 06:51 PM
Once you tune one truck the tuner will be VIN locked to that truck. The only thing that you could use the tuner for on a diff truck is to pull DTC codes. So the short answer is no you cant do that.
Sent from my DROID RAZR using AutoGuide App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #7 of 11 Old 11-14-2012, 06:57 PM
Quoted: 19 Post(s)
Cant the vinlock be unlocked untill it has been performed 6 times, then there is the $150 fee?
FICM Testing Videos
post #8 of 11 Old 11-14-2012, 07:05 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
No, once you put a tune into a vehicle, it locks to the VIN. Then it won't unlock until you return the vehicle back to stock tune.
You can tune the first vehicle as much as you want because the SCT device has stored the VIN.
If you return the first vehicle to stock and use the SCT on another vehicle, then the SCT becomes locked to the second vehicle and uses up one of the "unlocks left". If you return the second vehicle back to stock to unlock the SCT, and goto tune the first vehicle, then the SCT uses up another "unlock".
Depending on which model SCT your using, it only has 3 or 5 "unlock". After all the "unlocks" are used up, you will have to send it into SCT to be reset with "unlocks".
Sent from my iPhone using AutoGuide.com App
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #9 of 11 Old 11-14-2012, 07:08 PM
Quoted: 19 Post(s)
Oh I understand now, thank you.
FICM Testing Videos
post #10 of 11 Old 11-14-2012, 07:18 PM
ZMANN's Avatar
Agreed ,,,,,,,,,,,,,,,
We Miss you Ronnie
ZMANN is online now
