Dashboss BP reading?
Does the EBP reading account for baro or do you have to subtract that off? I just pulled it up today while in the driveway after I got home and boost was 0 and bp was 1.4. Just wondering because the readings idling would suggest it's corrected for baro. Thanks guys.
There was a app update to correct the decimal reading of the EBP.
The latest update is Version 1.6 app, and the latest Gateway (ODBII connector) is Firmware 1.61. If you haven't updated in awhile, you may also find a lot more PID's. Just be ready to update again, DashBoss will be releasing the ICP Calc PID to read corrected ICP psi thru the ODBII port, no more "hand calculating" ICPv to ICP psi when running a custom tune. Check out your updates for the app in the iTunes Store, and check you Gateway Firmware updates in the link below. http://www.dashboss.com/downloads.html Sent from my iPhone using Autoguide.com App |
