FICM tune or SCT tune? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-08-2012, 08:24 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Looks like Im gonna send my ficm to ficmrepair for a "tuneup". I also see u can get a ficm tune for another $150. Question is and I hope I word this correct, can u run a FICM tune with a sct tune at the same time or is it one or the other...
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 12 Old 11-08-2012, 08:29 AM
Quoted: 341 Post(s)
Feedback Score: 5 reviews
You can certainly run them together!
I would get the Atlas 40 tune, and run it with whichever SCT tune as you please.
I've heard that a higher FICM tune does not like Strong SCT tunes, or Larger injectors.
Also If you EVER plan on towing, anything over an Atlas 40 tune will get your EGT's higher then you want!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
post #3 of 12 Old 11-08-2012, 08:35 AM
Eli beat me to it. Run both by all means. If you do run more that Atlas 40 just make sure you are all over those EGT readings
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #4 of 12 Old 11-08-2012, 08:36 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Also is one better than the other?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 12 Old 11-08-2012, 08:37 AM
Quoted: 341 Post(s)
What you mean...
Atlas 40 from Power Hungry Performance
(PHP)
Studded and Deleted
post #6 of 12 Old 11-08-2012, 09:19 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Is one or the other worth more,bang for the buck I guess you could say.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 12 Old 11-08-2012, 09:23 AM
Quoted: 341 Post(s)
I would definitely start with the SCT tunes first becasue they add power AND tune your tranny at the same time...
Plus it adds around 100+Hp compared to the FICM tune adding 40...
But the FICM tune is a nice addtion and helps spool up, and lower RPM response.
BUT... since your already getting the FICM worked on, It might be beneficial to just get it done.
GET BOTH
Studded and Deleted
post #8 of 12 Old 11-08-2012, 09:39 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
GET BOTH
Well that being said I guess the SCT might be the way to go first. Thank you guys for the response's!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 12 Old 11-08-2012, 10:08 AM
Quoted: 341 Post(s)
If/When you get the SCT, Try Tony Wildmans tunes for it... I am loving his tunes and I have ran Eric's, Matt's, and Vivian's tunes...
All of them will be nice, but IMO Tony's are just awesome
Studded and Deleted
post #10 of 12 Old 11-09-2012, 03:13 PM
POGLIFE's Avatar
Do the sct first. I did the Hercules ficm before I got my sct it was awesome added 100hp a month later I had to get a suncoast tranny. You need the tranny tune from the sct first
Sent from my iPhone using Autoguide.com Free App
2007 F-250, 6" LIFT, 37" TOYO M/T, ARP STUDS, ZOODAD MOD, 5" STAIGHT PIPE, BANJO BOLTS, PHP FICM HERCULESE 100, SCT X3, RECON LIGHTS...417HP 846TRQ ON PHP DYNO 5/5/12 WITHOUT SCT TUNES!
POGLIFE is offline
