FICM!! URGENT - Ford Powerstroke Diesel Forum
Old 11-07-2012, 04:09 PM
Exclamation FICM!! URGENT
Will a FICM out of an 03 work in a 05 just found out its going out dont want to mess up my injectors if anyone has a FICM let me Know this is my main transportation!!
Old 11-07-2012, 04:10 PM
Sorry wrong place for the write up
Old 11-07-2012, 04:20 PM
they are interchangeable.
Old 11-07-2012, 05:03 PM
Thanks!!!! Now i just pray i can find one
Old 11-07-2012, 05:11 PM
Do the repair that is in the tech section....it's easy enough just take your time and don't over heat the solder.I did mine last year in less than 2 hours and have held 48.5v steadt ever since.
Old 11-07-2012, 06:11 PM
U have a link for it maybe??
Old 11-07-2012, 06:39 PM
Ficm voltage
Does anyone know what could cause ficm vo.Gage to fluctuate from 48 volts to 0 constantly? The input ficm voltage also fluctuates to zero from 12 volts constantly. I am monitoring this with an auto ingenuity scan tool. I tested the ficm voltage at the screw on the unit and maintained pretty consistent 48 volts?
Old 11-08-2012, 04:35 AM
Turbos = Witchcraft
My guess would be a bad connection at the FICM.
Old 11-08-2012, 08:15 AM
Also 03, and 05 FICMs are NOT interchangable !
Old 11-08-2012, 08:20 AM
Almostdunfukinwidit
Xjeeper as long as you have a complete 03 or a complete 05 to swap in theyre plug and play.
Whats not interchangeable is an 03 power supply side with an 05 logic board
