Different Strategy # after reflash - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-07-2012, 02:19 PM Thread Starter
Oilylizard's Avatar
So I had my truck reflashed today hoping to fix my cold start problem. Before I took it in I returned my SCT X3 back to stock. After I picked up my truck I was going to reinstall a tune and something told me to check my strategy and sure enough the number is different. Is this normal? I just dont want to screw up anything. Thanks for any input
2005 F-250 4X4
Harley Davidson Edition #00902
Leveled, Sinister Egr Delete, Studded, Sinister Coolant Filter, Rotella EC1 Coolant, 58v FICM, 6.4 Banjos, Blue Spring, SCT Tuned by Innovative, TSD
and the Wildman, Edge CTS W/ EGT Probe, 4" Turbo back straight pipe, CCV mod, 08 Tails, 08 Pan and filter, 08 Rear Diff Cover, 03 whistler
Oilylizard is offline
post #2 of 8 Old 11-07-2012, 02:53 PM
New strategy means that the tunes you have wont work. as far as I understand it
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #3 of 8 Old 11-07-2012, 03:02 PM Thread Starter
Oilylizard's Avatar
Dang thats what I was afraid of. I honestly didn't even think about a reflash changing my strategy. I thought returning to stock was all I needed to do.
2005 F-250 4X4
post #4 of 8 Old 11-07-2012, 03:44 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Uhm what part of getting reflashed means loading a new updated strategy didn't you understand? Odd are your old tunes will work fine. They will overwrite most of the newly installed strategy. You will often find that tuners use the strategy they think works best with your truck or that they are most comfortable with and not necessarily the strategy you currently have on the truck. For example Matt Robinson at Gearhead bases all of his tunes for the 05-07 6.0 off of the VXCF9 strategy regardless of what is currently on your truck. Chris B. at TSD prefers VXCF4.
RIP Mitch
the Org crew
PGreenSVT is offline
post #5 of 8 Old 11-07-2012, 04:03 PM Thread Starter
Oilylizard's Avatar
What can I say? Had a brain fart. I think I'll just get in touch with Innovative tomorrow and make sure everything is good to go. Thanks for the input though. I've read plenty of your post and your input is always top notch.
2005 F-250 4X4
post #6 of 8 Old 11-07-2012, 04:21 PM
pizza pig's Avatar
you are fine, i've never had a tune that was built for the strategy that was previously in my truck. Load up and youre good to go.
pizza pig is offline
post #7 of 8 Old 11-07-2012, 04:28 PM
portcity_gt's Avatar
Quoted: 1402 Post(s)
Vivian swears by the vxp1, (what's in my truck) but then I read its one of the worst ones to have.
Then on the other hand I read so little of the strategy is used in a custom tune these days it dosnt matter and sct custom tunes will work with many different strategys without rewriting the tunes.
So I have no idea what's true, I wish I did know!
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #8 of 8 Old 11-07-2012, 04:41 PM Thread Starter
Oilylizard's Avatar
I guess I'm going to go for it. Fingers crossed!
2005 F-250 4X4
