and the officially worst designed downpipe award goes to........(drumb roll)...... - Ford Powerstroke Diesel Forum
post #1 of 24 Old 11-05-2012, 01:38 AM Thread Starter
Quoted: 9 Post(s)
Silverline! lol. I don't think anyone could have put a guillotine clamp in a worst spot than where Silverline designed it! Right where the tranny lines/dipstick tube are. Plus it is a 3.5 inch (I know that is the optimum size for fitment) downpipe is about 1/4 inch smaller than the coupling on the next pipe. There is exhaust gas leaking from this union Compared to my Cummins this exhaust system leaves plenty to be desired. Anyone else have this problem?
I can't complain too much though since the rest of the fitment was good and the sound is perfect, not too loud, but still have the Harrier whistle.
Jeff
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow, Riff Raff turbo boots, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs.
1998 Dodge Viper GTS. Silver/Blue stripes 1 of 21: Corsa exhaust, high flow cats, K&N filters, smooth tubes
Invasivore is offline
post #2 of 24 Old 11-05-2012, 02:09 AM
BucOff's Avatar
That sucks to hear. I almost went with the Silverline kit on my EX. Luckily the Diamond Eye 4" turbo back fit perfectly with no issues at all.
GPDA Member...
Stock Turbo / Stock Sticks
439 rwhp/863 lb/ft.
BucOff is offline
post #3 of 24 Old 11-05-2012, 02:28 AM
I put the grand rock powerflow system on my truck and love i t. Fit was exceptional and the hardware was better than any other system out there.
Onefaststang is offline
post #4 of 24 Old 11-05-2012, 03:38 AM
Send a message via Skype™ to bwmtnbiker
That's odd, I have the silverline kit on my truck and it fit pretty good, no problems here.
My RAZR made me send this...
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #5 of 24 Old 11-05-2012, 09:12 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Get rid of that stupid clamp and replace it with a band clamp. Issue resolved. No more leaks.
Other end of the down pipe but these are all I use on my exhaust. Doesn't leak and doesn't crimp the pipes so it is easy to take apart.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 24 Old 11-05-2012, 11:21 AM
I used one of those on my DP and should have used them on the rest of the juctions. Regardless of me using the band clamp like that, my DP still would not come out at all when I did my EGR, all I could get it to do is spin.
-Brian
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-Blue Spring Mod
-Oil Cooler
-OEM Cab Lights
Wants/Soon
-ARP Studs
-6.4 Banjo Bolts?
post #7 of 24 Old 11-05-2012, 01:15 PM
my mbrp puts the clamp by the dipstick too
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #8 of 24 Old 11-05-2012, 01:58 PM
PGreenSVT's Avatar
I've had mine in and out several times. It takes 2 people to get it apart but with those ubolt clamps forget it.
RIP Mitch
the Org crew
post #9 of 24 Old 11-05-2012, 01:59 PM
Korx's Avatar
My diamond eye has the exhaust clamp for the down pipe is in the same place.
2004 6.0L F-250 XLT - ECSB
CTS SCT
Deleted
Studded
5" Exhaust
175cc Injectors
1995 7.3L 5-Speed F-350 XL Dump
Stock
Korx is offline
post #10 of 24 Old 11-05-2012, 03:11 PM
Pro fuzz's Avatar
Quoted: 29 Post(s)
On my down pipe( silver line) I used the Oem clamp off cat pipe band style works perfect !!
2006 F350 KR cclb 155/stock full force powermax / WWII leveled carli 2.5 pintops 08&up full rear spring ouo 3link arms 36 toyo mt 4.30 yukon grizzly rear locker :yike
s:
New ride 2015 tow boss dpf & egr lost !!
Pro fuzz is online now
