intake question
So i'm getting my truck ready for a MTW stage 1. Whike I was in there pulled the intake out to clean and cut off the back crossover section. My question is what the hell are the two electrical plugs for on the intake elbow looked around and don't see any sensor ports on them any idea it is a 03 no butterfly valve either.
ok never mind found it
All 2003.25 6.0L Power Stroke engines are equipped with a throttle body. • Some early versions also have a throttle plate in the throttle body. Later versions will retain the throttle body, but not the throttle plate. • The throttle was designed to assist with EGR operation, but later was determined unnecessary. • The PCM software for controlling the throttle body was not added and the plate was removed. • The throttle body may become operational for the 2004 model year. • Note: All engines have the wiring plugged into the throttle body and position sensor even if the throttle plate is not present. |
I put an 04 intake on mine. Found it onn eBay for $85.
sent from a dumb guy with a smart phone |
