Does any oone know shops that will beef up my trans. to withstand 700+ HP and also a shop to make my 6.0 a monster? I am about to buy new injectores and turbo but before I do that I think I need a new trans. and also I might aswell make the six a beast I am new to diesel I know how to make a gas. bad to the bone is it pretty much the same as gas bore it out new heads, cams, etc? I need any info I want my truck to smoke the ss camaro and challengers.
I forgot I live in morgan city,LA 70380 looking for shops near by I am willing to travel about 5 hours but it must be a real good shop. Let me know what you got and where it was done or the parts I need to get to get me 700
For the transmission take it to BTS (Brian's Truck Shop) in Arkansas. He is one of the best trans builders available. Well worth the drive.
700+ horsepower, easy Fuel system, $1000-$2000 Injectors, $1500 -$3500 Turbo, Single - MTW Stage 4 $3400, Compounds $6-$8000 Exhaust, $1500-$2500 Trans, $4000-$6000 Intake, $1000-$1500 Intercooler, $1000-$2000 Misc- $1000-$3000 So lets say $15000 to $20000 and you're there. It gets real expensive once you pass the 500-rwhp zone.
Thanks I know already about the price these things are no where near the price of gas I done put over $3,000 into doing the stuff myself. Cant wait to test her out maybe tomorrow I will have her back together and the rest my parts in. thanks I seen you posted about them b4 if any one else knows about BTS let me know.
There are only two places I would let build my trans. One is Brian at BTS and the other's name is Paul. He builds all of johnathon's trans of lead foot diesel for his pulling trucks. And as Mitch already pointed out its going to get very costly quick fast and in a hurry shooting for 700+ hp so be ready.
Also Mitch don't forget about either an adrenaline hpop or dual hoops depending on build stage. Also if you don't have a mid 04 it's going to be even more money to convert your truck to the mid 04 style hpo system.
I have '07 built in march of "06 I think. Dont clown me but is HPO high pressure oil? If so do I need to upgrade HPO for a bigger and better turbo?
Yes hpo is high pressure oil. If you want 700+ your going to need pretty big injectors and most of them will need a performance hpop to get every ounce of power out of them. That said there is currently a prototype 05-07 series adrenaline hpop being beta tested but no real word on when it will be released. The only option for us 05-07 truck owners is to convert to the 04 series style pump and run the adrenaline pump. Which also is not cheap.
I'll fill you in. Mine was at 674hp with 205/100's and a s364/s475 combo. Plus, the suncoast tranny, gogo intake, outlaw headers, banks ic, etc...
I done everything myself except build the tranny, stud job, and head work and had around 14k in it. I chunked #7 rod out the block and did a 24v cr swap, that added about 3k on top of that as I sold my engine and tranny as a takeout and done all the work on the cummins myself and repurposed the ADII and s364. I haven't went down the track but this engine dynoed 716hp. Doing the math, it comes to $23.50 per hp. that's not counting the axles, suspension. But, it is cheaper to just go huge the first time and skip the buying and losing you A$$ on reselling smaller stuff. So if that's what you really want, by all means go for it, talk to MPD, Cutting-Edge-Diesel, they can get you a detailed parts list, but be prepared to cry when you see the totals. then add labor as alot of things need fabbed up to work. |
Kdogg a cummins swap isn't exactly the cheapest thing or easiest to get 700hp. Hell if you really want to be realistic here is a combination that could get you at or over 650 rwhp and relatively cheap compared to kdogg's purposed setup.
MTW stage 3 $2900 190/100 injectors $1000-$1750 Complete fuel system with fuel bowl delete and rr $1000-2000 Exhaust $300 Intake $250 Tuning $300-$500 It's already been done and can be replicated. |
