Anyone Running Gillett Fuel Spring?
Any one run a gillett fuel spring? $20 ain't a bad price. It runs higher PSI than the blue spring kit.
Do a quick search for Gillette in the 6.0 section and you will soon read about the spring being detrimental to our trucks. Your best bet would be get the "blue spring" upgrade direct from Tousley Ford. You could use your local dealership, but Tousley is typically the cheapest around even with shipping.
I did search. I did not find one post with some one using the gillett spring caused the o-ring in the injectors blow out or any problems. The few people that have actually used them had no problems.
Every body that said that the PSI is too high has no experience using the gillett spring. I'm looking for some one that has ran one in their truck and not some one that says they run too high of PSI but never used them |
I ran one with No issues. Switched to the blue spring because I read all the warnings on too high of pressure, and then switched to an AD2. I have a Gillette spring in the garage I ordered for a buddy and then he totaled his truck. Pm me your address and I'll send it to you.
Sent from my PC36100 using AutoGuide.com App |
Sent from my ADR6350 using AutoGuide.Com Free App |
I run on on my truck with no issues so for. I actually make this spring for Gillette diesel.
Aside from the 95+ at idle, I didn't see any difference. Unlike Term3, mine would drop to low 60s~mid 50s at WFO. Not saying he's wrong, but mine had been in for a couple of years before putting a PSI gauge in. Further, I agree that there are plenty out there only parroting what they have heard about the Gillette spring (as well as other "out of the ordinary" parts/processes) without actually having used/tried it. Your obligation is to do your own research and make a decision from there. Trust me, in most forums, different is wrong. As you have seen, calling out for experience not theory gets you hate mail. sent from a dumb guy with a smart phone |
Higher pressure will do nothing for you, you will loose performance from it.
Read this thread Regulated return turn fuel psi down:: |
