Buying a FICM - Ford Powerstroke Diesel Forum
Old 10-26-2012, 01:02 PM
Buying a FICM
I am thinking about buying a used FICM. It is off another year 6.0 Mine is an 05 and I believe it is coming off of a 04. Will it work on my truck? does the strategy change? I believe it has the Atlas 40 on it, does that change anything?
Old 10-26-2012, 01:51 PM
Feedback Score: 3 reviews
Yes all 03-07 FICM are interchangeable, you might get a U0306 reference code for the strategies (programming) don't match, but won't effect drivability.
Old 10-26-2012, 01:53 PM
If i get that code do I let my tuner (Vivian) know I changed FICM? Truck has looney on it now. wouldnt want it to not start LOL
Old 10-28-2012, 03:40 AM
even 7 and 4 pin?
I've got a 7 pin going south fast and BPD only does 4 pins currently.
Old 10-28-2012, 05:27 AM
Vivian can't help you with the U0306 code, you would need to contact PHP to have the FICM strategy changed to match the PCM strategy group. Here is a copy paste from Bill at PHP.
The U0306 DTC is a mismatch between the RCM and FICM strategies. This code is more of a reference code and is NOT an indication of anything that will affect driveability, so there is no real concern. In order to eliminate the DTC, you must use the correct FICM strategy with the correct ECM strategy. The relationship is as follows:
2003 Model Year:
ECM: VXAxxxx
FICM: 2003 FICM Strategy
2004 Model Year:
ECM: VXBxxxx
FICM: 2004 FICM Strategy
2005+ Model Year:
ECM: VXCxxxx
FICM: 2005+ FICM Strategy
Old 10-28-2012, 08:28 AM
Ok thanks lilpooh
Old 10-28-2012, 11:19 AM
MAD - Modification Addict
Feedback Score: 7 reviews
Dever02, You might want to consider the possibility of popping your head gaskets with the atlas 40 and Vivian's Looney Tune if your not already studded. Just a concern to watch for. I know that they say it's safe for stock bolts but I would be weary about advancing fueling anymore than it currently is with stock bolts and the Looney Tune.
