Snow plowing with a 6.0 - Ford Powerstroke Diesel Forum
Old 10-24-2012, 03:05 PM
Any one know of any issue's with plowing snow with a 04 F 350 with a 6.0. My only thought was power for the FICM while running the plow. I haven't heard of any issue's, any one in here heard of anything?
Old 10-24-2012, 03:08 PM
My buddy's 6.0 has done great plowing. Of course it is going to see more wear and tear but he changes the trans fluid a lot during the winter as well as the oil more often. He did have to do head gaskets but hey that's just being a 6.0 Maybe that was due to running xtreme street while plowing with two yards of sand in the spreader lol. Do you have plow prep? The only thing to note would be having the stiffer springs as well as an upgraded fan clutch.
Old 10-24-2012, 04:05 PM
Thanks for the reply! I don't know about the plow prep but the plow was put on when the truck was new but was only on the truck a couple times over the year's. The fan clutch was changed at one point. I have a super chips tuner, probably would be a good idea to run the tow safe tune and changing the oil more often would be a good idea. I don't do a lot of commercial plowing any way, two to four hrs max per storm. Should be OK!
Old 10-24-2012, 04:49 PM
Only plowed the one storm last winter with my 6.0. Had an 8' pro plus on it, ran like a champ! My fuel economy actually went up since I wasn't driving like a ****. Drove 4 hours highway time with it on too and plowed an entire street. No problems whatsoever
Old 10-24-2012, 05:27 PM
I wonder what a plow up front would do to those of us w/ BPD oil cooler ??
Old 10-26-2012, 02:44 AM
I ran my 550 last year plowing and my EOT never exceed 190's. thats after 24+ hours of running straight. plow up is a bit different. when its down its fine.
Old 10-26-2012, 03:13 AM
My old man plows.with a 6.0. I would reccomend high output alt. Or at least an overdrive alt pulley.
Old 10-26-2012, 08:17 AM
High output alt or dual alts like I had are definitely a plus
Old 10-28-2012, 09:28 AM
My truck has a powerbastards 220amp alt on it and snow plow pre fan clutch on it. as well as an extra leaf up front.
Truck hold my plow great. barely drops more then 1/2inch with the plow up.
As far as plow. just be smart, allow the truck to stop before shift, unless you like doing transmission swaps. good fresh fluids make a world of a difference. my trans fluid has 5k on it right now. ill change it again in 10k. Always let it to spend some time cooling off after a run.
These trucks love to work. keep them healthy and they will do great. Cant wait to start pushing this season. last season was a weak one for us.
Old 10-28-2012, 09:40 AM
My 6.0 is a snow plowing SOB
