EGR delete info
looking into deleting my egr and i have been looking at all the forums it seems like and im not finding the anwsers do i leave the valve in and pluged in or take it out completely will it effect my turbo or fan if i take it out or whats the deal with that even with it turned off whats the best to do with it? ive even heard to just leave it on the motor plugged it so it will oporate so whats the best to do and whats the best kit out there one with a plug for the exhaust or one tht replaces the pipe going nuts here thans
It depends on your year, as I understand it, the early years can be unplugged and not throw a code, and after about 2004.5 (someone correct me if I'm wrong)...it'll throw a code if unplugged. In my 05 it throws a code if unplugged, but when I deleted mine, I just took the valve out and left it resting next to the oil filter housing still plugged in. No codes or issues at all. Also, a custom tune can turn tell the computer not to look for the egr valve, and therefore not throw a code.
While we're on the subject, if your egr cooler went out, it's likely because your oil cooler is bad, or going bad (starting to clog up)...a rebuild or replacement is usually necessary, I flushed the crap out of mine still in the truck, lots of distilled water and "restore" and "restore plus"...there's write ups on how to flush it...anyway, then the use of an ELC coolant is recommended (I used Rotella Ultra ELC). It doesn't gum up the oil cooler the way the ford gold coolant does. Then I added a sinister coolant filter...it's relatively cheap, and my temp delta's have been great since, without changing the oil cooler. I may have gotten lucky...so I was told by several on here who reamed me for not changing the cooler while I was in there. Anyway, good luck. Hope it helps. |
well im not having any issues with y truck just want to prevent sothing from happening as best i could beacuse im getting a programer next spring/summer so just looin for the best way some say its a way to make some more hp but little bit of both would be good but whats the better way to do it by replacing the exhaust pipe or getting the one with just the plug and whats a good quality reliabe one lots out there what one do you have
yeah mines an 04 to. did you notice any kind of performance increase in it or not beacuse according to truck you it helps but not to sure how uch of that is true. yeha im in ny so we have inspections here but it helps to have a lisense to do them
Be sure to update your turbo drain tube and whatever else needs updating while you're in there. I'd also ad the blue spring while you're under the hood, it'll be easier without the cold side cac tube in place. I might have mentioned it already, or someone else might have, but I've slept 6 hours total over the last 2 days and can't remember...but add a coolant filter if you haven't. Clean coolant is imperitave if you're going to run a stock oil cooler. Even if everything is good now temp wise...I'd still ad one. Cheap insurance. There's a reason tractor trailers have coolant filters. Anything with a engine oil cooler needs a coolant filter in my opinion. |
honestly i didnt notice any difference except the exhaust sounded a little different, but thats because i replaced the up pipe also.
Depending on your stategy, the EGR valve is REQUIRED for proper VGT cycling. Considering how Ford butchered our ECUs when they "serviced" our trucks, I'm more concerned about VGT cycling than codes/lights.
sent from a dumb guy with a smart phone |
so from what im reading now i should leave the valve in ang pluged in, i already have my blue spring in, how much work is it to change the oil cooler as long as im in there, also does the intake need to come off ive seen in dp magazine that they didnt have to remove it, thanks all
