trans temp and boost gauges
how did yall mount the sensors for the gauges
Here take a look at this link 3-Gauge Install Pictures
i dont run a tranny temp gauge but there are several options for the boost gauge.
you could drill/tap your intake manifold (preferred) or you could drill and tap your intake elbow before the throttle body (2nd best i've heard) or you could cut the hose going from the passenger side of intake manifold to the MAP sensor on the firewall and put a "T" in it and use that. personally i have mine tapped into the factory boost line going to the MAP sensor, but i will probably drill/tap my manifold when i yank the motor next weekend. |
