full flow vs bypass coolant filter??
Wondering if anyone has measured results from running a full flow vs bypass (like my Sinister one) in the coolant system? Anyone run both types of filters?
What stops a full filtration system from clogging the filter and causing catastrophic failure? A bypass sytem will not do t his if the filter is clogged by nature of its design.
A full flow will obviously filter more, but I don't like them. First, noone has answered the question about how much a clean, full flow filter restricts coolant flow. Second, its the same as a clogged oil cooler when it does clog. As Karl mentioned, a bypass filter will still allow coolant flow even when its fully clogged. Hence the reason its called a "bypass" filter.
Some people will swear that a full flow filter is the only way to go, but I just don't buy it. Last edited by Snake; 10-14-2012 at 10:14 AM. |
I'm wondering how long it takes for a bypass filter to completely clean out the system.
I'm using my ipr filter to filter 100% of the coolant before it goes into the oil cooler, as long as you have a monitoring sorce it's fine......deltas go up, clean the filter it's that easy.
I'm not sure what to think about the IPR kit.....in one regard, this diminishes the value in my opinion. If there's unfiltered coolant going through the oil cooler, its obviously much more likely to clog again at some point in the future. Obviously not as quickly as a motor without a coolant filter (or a bypass filter that cleans less coolant), but the risk is there. On the other hand, a clogged coolant filter won't completely block the flow of coolant, which is a plus. I dunno. There's an advantage with the kit for sure, but I still don't believe it's a 100% solution. Last edited by Snake; 10-15-2012 at 10:49 AM. |
Mike the only 100% solution to clogged oil coolers is the BPD kit and even then some will argue that it isn't capable of handling the cooling duties on 100% of the uses these trucks see, so I'm with you. I dunno.
Even using the coolant filter by itself without the remote oil cooler mount it is the most effective coolant filter currently on the market and still well worth it from that point of view as well. Last edited by PGreenSVT; 10-15-2012 at 09:44 AM. |
Is their filter a bypass or does it filter 100% of the coolant?
