MAG-HYTEC tranny pan - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-22-2007, 01:01 AM
nightworker
Guest
Posts: n/a
Quoted: Post(s)
Just a heads up conserning the mag-hytec tranny pan, this pan has a bad habbit of leaking when towing at the rear of the pan where it is narrow.
Nothing worked to stop it and unless there is a company that makes coustom gaskets for them , the stock pan stays on . it worked great untill the pressure and heat was on ( it never over heated) its a great product but needs a real gasket.
post #2 of 5 Old 10-22-2007, 01:09 AM
red73psd's Avatar
thanks for the info i was thinkink about getting that.
2010 DODGE 3/4 CUMMINS 6 SPEED MANUAL 4X4
(SOLD)2006 dodge 2500 cummins 4x4 6 speed full 5 inch strait pipe brute force intake edgejuice with att. hot unlock. sbc 3250 dd clutch weighted powder coated shift knobs dc mud country tires and a leveling kit smarty 2nd gen exhaust manifold and htt 62 65 12
441hp 920tq
red73psd is offline
post #3 of 5 Old 10-22-2007, 01:32 AM
nightworker
Guest
Posts: n/a
Quoted: Post(s)
The gasket is the only weak part .. there great pans and didnt leak under normal driving .
post #4 of 5 Old 10-22-2007, 01:33 AM
red73psd's Avatar
what kind of temp change did you see
441hp 920tq
red73psd is offline
post #5 of 5 Old 10-22-2007, 01:37 AM
nightworker
Guest
Posts: n/a
Quoted: Post(s)
temp ran with normal driving - 135 to 160 . towing at max was 180 pulling a 30 ' trailer through the western moutains ,
