EGT probe placement question- - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-09-2012, 07:25 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
I know that most guys like to drill/tap the exhaust manifolds to put their egt probe in but, would it be bad or inacurate if I was to drill and weld on a nut on the 5" down pipe as close to the turbo as possible of course. Juz seems a easier route.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 8 Old 10-09-2012, 07:28 PM
mazsecond's Avatar
Feedback Score: 4 reviews
Putting the probe on the exhaust manifold will give you pre-turbo EGTs which is what most of us are after. Mounting the probe on the downpipe will give you post-turbo EGTs. Not sure how much of a difference their actually is, but I would be curious.
Mike
mazsecond is offline
post #3 of 8 Old 10-09-2012, 07:36 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Usually a post turbo reading varies between 150*-300* lower than the manifold temps.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #4 of 8 Old 10-09-2012, 08:07 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Temps of the exhaust will be MUCH higher pre-turbo as compared to post turbo due to the fact that energy contained in the exhaust is being expended to spin the turbine wheel and therefore results in a lower temperature after it has gone through the turbo. Hope this makes sense as it just isn't a distance thing.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 8 Old 10-10-2012, 07:23 PM
04cr450's Avatar
on my truck it measured about 275-320 degree diff. pre and post turbo. Its flucuated fast when i tested it as you can see with the temp range.
04cr450 is offline
post #6 of 8 Old 10-11-2012, 07:29 AM
Int.Tech04's Avatar
im kinda at a loss for this also. i mean, i see Cat engines and Cummins engines constantly (road tractor) with the EGT probe in the downpipe about an inch and a half behind the Vband. if its good for them, why wont it work for ours. could i put it in my up pipe im about to replace when i do my EGR delete?
Int.Tech04 is offline
post #7 of 8 Old 10-11-2012, 09:54 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
It works either way. One thing to remember here is that most road trucks aren't being turned up in hp ranges. They are designed to pull extremely heavy loads and not get the exhaust temps to hot. We put ours in the manifolds because this tells us what kind of temps are exiting the cylinders. A lot of us are also pushing higher hp levels than intended by ford or international when they built this engine. Personally I have 3 egt probes installed. One in each manifold and one post turbo about 6-8" down the down pipe. This allows me to watch all temps at any time.
l BRYAN l
COMPIGNTECH .COM
[A Few Odds-N-Ends]
Tuscany is offline
post #8 of 8 Old 10-11-2012, 11:06 AM
Erwin8r's Avatar
Any tips for getting the probe(s) in without tons of disassembly?
Thanks.
2003 6.0 PSD Extra Cab SB 4x4
35" Toyo MT's
ARP Studs
BPD EGR Cooler
AFE Stage 2
Rhinoliner
Big-*** Fuel Tank (47 gallon?)
Erwin8r is offline
