Which EGR delete and oil cooler kit? also thinking about delaying stud install - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-07-2012, 11:11 AM Thread Starter
Quoted: 9 Post(s)
Are all the EGR kits created equal? I hear horror stories of coolant leaks with some of them. I also don't know which oil cooler rebuild kit, stc fitting, oil feed/drain tubes, dummy plugs, standpipes to purchase.
I think I'm going to do this without putting studs in right now. Im thinking of paying someone to do the studs since I can't pull the cab or really take the heads off.
Has anyone re-torqued/over torqued factory head bolts with success?
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow, Riff Raff turbo boots, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs.
1998 Dodge Viper GTS. Silver/Blue stripes 1 of 21: Corsa exhaust, high flow cats, K&N filters, smooth tubes
Invasivore is offline
post #2 of 9 Old 10-07-2012, 11:42 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Look at my build thread link in signature.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #3 of 9 Old 10-07-2012, 12:45 PM
Quoted: 2 Post(s)
I just put the new IPR EGR cooler delete kit on my truck and feel like I made the right choice. It's the pricier of the bunch, but it doesn't look like it'll give me any trouble.
Re-torquing and/or over torquing stock head bolts is always a bad idea. The OEM bolts are torque to yield bolts, which stretch with the amount of torque applied to them. This makes them non-reusable. Unless of course you run a cash only used car lot and need to do a cheap fix.
---Garret
2006 F250 6.0 XLT FX4 CCSB
S&B Intake
MBRP 4" straight pipe with 5" tip
Studded and deleted
CTS w/EGT
Atlas 40 and Looney Tuned
2002 F250 7.3 XL Reg Cab 2wd Sold!
1995 Ram 3500 Dually Reg cab 5.9 12v auto 2wd
Fordtrucktexan is offline
post #4 of 9 Old 10-07-2012, 08:41 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
As we speak Im in the middle of a full Bullet Proof Diesel oil cooler with winter package with a EGR upgrade. It was same price (egr upgrade or delete) and after talking to the folks at BPD decided to go that route. And Im doing a ARP stud job with out removing the cab, yes I am proof it is possible. How hard you ask? Well I have 5 diffrent burn marks from the drop light...but I now have a fully studded 6.0. Fair trade!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 9 Old 10-08-2012, 01:50 AM
dieseldan73's Avatar
If you're mechanically inclined, go the route I did. I had no way to lift the cab nor did I want to strain my back and take the a/c housing off. I pulled the fan, radiator, and intercooler out and then had the engine out and on a stand in an hour and a half. I bought an engine removal plate on ebay and didn't even remove the grill or hood. It came right out the top. I would not do it any other way. Plus you can upgrade the torque converter while the engine's out.
2005 Ford f350 CCSB King Ranch
MTW MadMax Turbo
Warren 155/30 injectors
EGR Delete
BPD Oil Cooler, FICM, Oil Bypass, Water pump
Flo-Pro 5" Exhaust, Cat Free, Muffler Free
All updated FORD Parts
ARP Studs With Factory Gaskets
PI Stallion Converter
TSD SPD. Thanks Chris,
Edge CTS monitoring
35x12.5x20 Dick Cepek FC-2 on Chrome Rockstars
4" Zone lift with Bilstien 5100's
dieseldan73 is offline
post #6 of 9 Old 10-08-2012, 05:14 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I hate to say it but he might have a point....oh well as long as it gets done!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 9 Old 10-08-2012, 05:22 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
This VERY true. I have seen first hand now the IPR kit, Sinister kit, and the cheap one from Ebay and (IMO) for the money, I would just spend the dough on the IPR kit. Vince does such a GREAT job with that coolant return piece, it's AMAZING (almost as cool as the BPD oil transfer block). I'm a sucker for machined aluminum.
Yes NEVER re-torque the OEM head bolts as doing so will gain you nothing except lessing the clamping force on the heads. Your only option is to replace them with studs or new bolts (if you loosened them in the first place).
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #8 of 9 Old 10-08-2012, 11:19 AM Thread Starter
Quoted: 9 Post(s)
Are the standpipes and dummy plugs easy to change?
post #9 of 9 Old 10-08-2012, 11:20 AM Thread Starter
Quoted: 9 Post(s)
Any special tools or recommended ones needed?
