2006 F350 Stock for now - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-05-2012, 07:47 PM Thread Starter
Looking at a few different options to start building from. The truck is stock currently but looking at getting an exhaust system and air intake. These are the few things I have found that I like so far can you guys give any options or suggestions on which way to lean?
I am wanting to start building up hope to bulletproof soon and would like to have a decent start for when the bp is completed.
MBRP XP Series
MBRP XP Series T409 Stainless Steel 5" SINGLE
AFE Cold Air Intake
AFE Stage 2 Cold Air Intake System Type Si 54-81022
drew.jackson is offline
post #2 of 6 Old 10-06-2012, 07:32 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Welcome, 2006 is a great truck. Won't stay stock for long if your on this forum! I have never found a reason to replace the stock air intake, what is yours? Air to engine is produced by turbo, intake doesn't do much in the way of helping that process, much different process than gas motor. Check out diesel site coolant filter, that would be money much better spent. And get some gauges or a monitor so you can start watching your parameters. Welcome.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 6 Old 10-06-2012, 08:00 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Jetjock is right in that the gains are nominal with an aftermarket air intake system and the stock turbo, but there are small gains to be had and you will degrade your filtration slightly and the capacity to hold dirt significantly. However, as long as you don't live in a dusty/dirty environment and really only drive about 12-15k miles a year, you can get away with changing an aftermarket intake filter once a year. I have a S&B and I REALLY like it and bought it because it was $100 less than AFE. AFE is still a good system. Just trying to save you some money. Furthermore, if you do decide to upgrade your turbo to anything over stock, you're gonna want an aftermarket intake filter (I am sure you will be hearing soon that the stock filter is good to 500hp. Blah Blah Blah) to help ease the strain of having the turbo suck so hard. JMO of course.
I really like Magnaflow exhausts as I think they sound REALLY good but the MBRP exhausts are good too and you'll be fine with that.
I have an 06 6.0 and I have had good luck with it so far. I think they are great trucks and I still love driving my truck (even more than my Harley Street Glide).
BTW welcome to the .ORG. Ask away on whatever you're thinking about. I think you'll find A LOT of knowledgeable people on here that can get you sound information and help save you some money if/when you decide to build er up. Take care.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 6 Old 10-08-2012, 06:47 PM
DoubleDpsd's Avatar
I would also look at diamond eye exhaust systems as well. Or if you have a muffler shop in your area with 4" pipe you can buy just the downpipe and over axle piece and possibly save a couple bux.
Sent from my DROIDX using AutoGuide.Com Free App
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #5 of 6 Old 10-09-2012, 07:55 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Do u have a monitor yet? I would start their first. For exhaust I got the diamond eye 5" tb...love it. Intake running stock is the way to go up to 500 hp!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 6 Old 10-09-2012, 08:03 AM
DoubleDpsd's Avatar
Like said above, blah blah blah. Lol Airaid or s&b are great set ups and less expensive than afe which is also good.
