Custom tunes + ficm tuning - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-04-2012, 05:31 AM Thread Starter
Kyleu890's Avatar
Truck in sig, plus new factory flow injectors! I am really wanting to run ficm tuning because of the reviews I've read will give me what I'm looking for. I'm just wondering if I buy php gryphon module, does it provide safe power for an unstudded truck if I don't put it on the Hercules 100 hp setting and just keep it on the atlas 40 or 80? I'm currently running Vivian's looney but am thinking about venturing to see what the srl is all about an run that an the php tune in conjunction with it. Then do the same for the looney to see which combo I like better. All I'm asking is if these ficm tunes are safe to run say if I know I'm going to be running with my buddies DMax one night and don't want to let him by.
Thanks for any Info in advance!
04 ccsb f350 little red rip! Previous truck
05 ccsb f250 currently bone stock no plans to change it.
Kyleu890 is offline
post #2 of 17 Old 10-04-2012, 05:41 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
You'll be fine in Atlas 40 or 80.
Ive seen people run Herc without studs too. But I wouldnt recommend it
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 17 Old 10-04-2012, 05:43 AM Thread Starter
Kyleu890's Avatar
Anything I should keep my eye on while running the added power?
Kyleu890 is offline
post #4 of 17 Old 10-04-2012, 05:45 AM
high exhaust temps.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #5 of 17 Old 10-04-2012, 05:56 AM Thread Starter
Kyleu890's Avatar
What is high, but acceptable for a few seconds like if your making a pass. And what is just down right to high. I have my alarm set to sound at 1550 on my insight. Is that ok?
Kyleu890 is offline
post #6 of 17 Old 10-04-2012, 06:03 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
i dont even go to 1550 lol i let off at 1400
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #7 of 17 Old 10-04-2012, 06:07 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
1550 is ok for short bursts.
1250 is max sustained.
I saw 1780 last saturday
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 17 Old 10-04-2012, 06:09 AM Thread Starter
Kyleu890's Avatar
That's just what my Alarm is set at, I've only heard the alarm sound once.
Kyleu890 is offline
post #9 of 17 Old 10-04-2012, 07:51 AM Thread Starter
Kyleu890's Avatar
Also my other question is with ficm tuning and my looney or (srl to come) what kind of general numbers can I expect as far as power wise, and will this land me in the 13's at the track?
Kyleu890 is offline
post #10 of 17 Old 10-04-2012, 08:43 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Should put you at about 430-450 if fuel pressure keeps up
Email:
Edge Insight CTS
Coolant filter
Dave is offline
