s&b intake 6.0L
I have been in the market for an intake. One that really caught my eye was the s&b system. It stops almost all the dirt and flows really well from what i here. If anyone who has info on this intake or another i should look into please post. Thank you.
do you want something to filter good or flow air? because most aftermarket intakes DO NOT filter as good as the stock donaldson but it is my opinion that the stock intake does not flow as much air as my afe stage 2 with pg7 or blue media filter. I only have experience with airaid and afe and I like my afe A LOT more than the airaid and stock.
Yea that afe stage 2 with progaurd 7 filter is really good. Does anyone have any input on a good intake for the 6.0L
the stock intake does very well for the 6.0L but if you really want to go with an aftermarket filter the AFE stage 2 will be the best
That afe system is pretty pricey. What have you heard about the s&b compared to the afe.
honestly never even dealt with that intake before so i cant give you any info on it.. sorry
i thought about buying that s.b. intake with a larger elbow for more flow, but i need more feedback....
wait i found some mixed reviews on the product from autoanything.com
"2005 Superduty 6.0 diesel. Install would have been faster if maker had cut slots for original plastic intake in correct spot. Had to cut slots wider with Dremel tool. After that fit was ok. Around town and at idle noticed more noise (naturally)and performance and mileage about the same. After pulling trailer to Colorado, unit seemed to perform well, no increase in mileage, but off idle turbo boost seemed to be slightly more responsive. Very loud and bad noise when let off on it on slight grade with maybe 4lbs boost at maybe 25 to 40 mph. Sound like back pressure from turbo and very loud. Loud enough for concern. Had my oem unit with me and pulled the S&B unit off and put it back in the box. Noise went away. All areas were sealed good when this noise was evident. The noise I mentioned sounds like someone trying to tear the firewall out with a backhoe and I am not kidding. I liked the design of the system, but am not impressed at all with the performance. I had done lot of research on S&B before purchase. They have a good article this month in Trailer Life but I am not impressed after using this system and I waited for about 2 mos before sending this reply because I wanted to give it a good chance. If someone from S&B would like to reply to this report I would like to hear from them, but until then I will continue to run the Original system and the money spent for this system was wasted as far as I am concerned. JS" "PUT THE S&B ON MY SUPER DUTY AND IT SOUNDS GREAT AND I GOT IT FOR A GREAT PRICE.THANKS FOR THE GOOD PRODUCT AND PRICE. TOOLMAN" "I have not seen any change in fuel miliage or power in my 2004 powerstroke. Icould buy alot of air filters for what it cost for my S&B air system." "My system arrived in good shape. It was easy to install, about 45 minutes. It has complemented my new chip and 4" exhaust on my F-250 diesel.More power and mileage. The fit wasn't perfect,but a little foam tape took care of that problem." |
S&B stands for Sh!tty At Best...
My buddy Harry has an S&B intake on his 04 Duramax, and he told me "its the best I could buy for my truck". So I replied "I did a diy Tymar intake, cost me about $30 and works awesome" He just looked at me as said "Only $30 bucks...."
