Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Performance Parts Discussion
Old 10-18-2007, 05:13 PM
bigjohnspowerstroke bigjohnspowerstroke is offline
5in MBRP exhaust
I am about to install a 5in MBRP cat back exhaust on my truck tomorrow. I was reading the directions and i saw that is said you have to remove the spare tire and it may not fit back in its spot. Can anyone tell me if the spare tire will fit back under the truck???
Old 10-18-2007, 05:17 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Seems to me I have heard that, but Im not totally sure.
Old 10-18-2007, 06:27 PM
holleywood holleywood is offline
why run a 5 inch cat back? Probly would be better to run a 4 inch back from Farm Boy then just get a 6 inch tip
Old 10-18-2007, 06:43 PM
04TurboStroker 04TurboStroker is offline
Send a message via AIM to 04TurboStroker
I ran the 5" a while back. What you have to do to make the installation much easier for you is remove the spare tire, then have a friend help you squeeze back in the tire once your done. You will have little spaceing b/w your spar tire and shocks! But over it will sound GREAT!
Old 10-18-2007, 06:50 PM
Marty Marty is offline
International Threat
I'd go 4" turbo back w/ a 6" tip!
Old 10-18-2007, 06:52 PM
One more important thing. If your full size spare has good tread, forget it, the pipe will just melt the rubber off. So if installed right you may not have any problems. Either way lose the spare or install the exhaust.
Old 10-18-2007, 07:09 PM
~CrazyDiesel~ ~CrazyDiesel~ is offline
Send a message via AIM to ~CrazyDiesel~ Send a message via MSN to ~CrazyDiesel~ Send a message via Yahoo to ~CrazyDiesel~
Yeah, with my 5" I've got about 1/3" between the tire and the exhaust, and about 1/2" between the shock and the exhaust, it's a tight fit. Granted, I shouldn't have gone with 5" with my set-up, but I wanted the extra deep sound, you know? The spare is a tire that's got very little tread on it, and I bet if it had lots of tread it'd be melty like you say.
It all depends on your preference though.. With the 5" with 4" DP, the exhaust rattles on the transmission corss member every once and awhile. If I had to do it all over, I think I would go with the 4"
Old 10-19-2007, 08:12 AM
farmboysdiesel farmboysdiesel is offline
5in turbo back system would certainly work but a 4in system is sufficient.
Old 10-19-2007, 05:54 PM
ncbowhunter ncbowhunter is offline
hey guys i found myself a muffler delete pipe the other day and was wondering how much different the sound will be. i have the 4 inch duals with cat delete and the mbrp muffler now. dont mean to steal the show just curious?
Old 10-19-2007, 05:59 PM
jostaman jostaman is offline
Smile could you
what if you dump before rear axle then you not have to lose spare at all.
this might help
http://www.powerstroke.org/articles/...all/Page1.html
