Archoil AR9100 Review - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 31 Old 09-13-2012, 07:37 AM Thread Starter
Talking Archoil AR9100 Review
I just wanted to give a quick review of my experience with the Archoil AR9100 oil additive. I don't normally give reviews on stuff like oil additive, but I was just so impressed with it I fealt like I needed to share my experience with members on the org. A little background on the truck is before I added the Archoil i was having long and rough starts. I always run T6 oil. The truck would have a real bad miss and would run like crap until it got to operating temp. From my research here I came to the conlusion that I was having injector stiction. I figured before I dropped the coin on new injectors I would give Rev-X a try and see if it helped any. Well I was researching the Rev-X and found out that I could get Archoil for A LOT cheaper. I ordered a 16oz bottle of the AR9100 and added it to my oil. At first I did not see any improvement and was kind of dissapointed. After about 2 days of driving to work and back I noticed it was idling a little quiter. Well it has been a week now since I added it and I am amazed. After sitting all night the truck starts like it has new injectors in it. It does not have a miss anymore and runs just as good after first starting as it does at operating temp. I would not hesitate to recommend this product to anybody that has sticition issues.
2004.5 Mods: CTS, Lots Of Gauges, 7 inch Stack, ARP Studs, Tuned by Eric, SAP Diesel Full Fuel System, WEP Ported Intake Manifold, Mechman Alt, BPD 6 Phase Ficm, BPD Oil Cooler, BPD Oil Bypass, Warren 350cc conventionals, SAP Diesel/Warren Diesel Twin Pump Kit, SAP Diesel Triple Turbos and SAP Diesel Trans in Progress.
g2shuck is offline
post #2 of 31 Old 09-13-2012, 09:09 AM
Joeshu1000's Avatar
I was having the same issue you were and tried RevX. I pulled the oil filter and dumped it i. Immediately I noticed a difference. After about three weeks the miss has come back, just not as bad. I'll have to give Archoil AR9100 a try on my next oil change.
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #3 of 31 Old 09-13-2012, 09:42 AM
strokin6L's Avatar
Quoted: 3 Post(s)
I started using rev-x 3-4 years ago, then switched to Ar9100 a year or so ago. Both are great additives. Only i switched to Ar9100 was because of price. I never had any issues with injector stiction, but i started using this stuff as preventative maintainance.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 31 Old 09-13-2012, 09:44 AM Thread Starter
ya I am super impressed with the archoil. I do not see a need to spend the extra money on the rev x
g2shuck is offline
post #5 of 31 Old 09-13-2012, 05:08 PM
That's all good news about AR9100 working for you.
To date we have not had a complaint, only success stories like yours.
2006, F-350, 6.0, 4x4, Lariat, crew cab, long bed
MagnaFlow 4" turbo back exhaust system
DC Power Engineering 190 amp alternator
Ranch Hand Legend grill guard
Firestone Ride-Rite air bags
HID Bi-Xenon headlights
HFCM water drain plug
Accufab intake elbow
Bilstein 5100 shocks
Ctek batteries tender
DFuser coolant filter
Blue Spring mod
ScanGauge II
Up-idle mod
Zoodad
ARCHOIL (AR9100, AR6200) & PRI-D & PRI-G Dealer
SnowGoose is offline
post #6 of 31 Old 09-13-2012, 05:11 PM Thread Starter
What is the pri stuff in your sugnature
g2shuck is offline
post #7 of 31 Old 09-13-2012, 08:05 PM
PRI-D & PRI-G are proven fuel additives. Click here for more information and a link to the manufactuer's site.
Link removed for COC violation. Not a Vendor.
I have a personal experience using PRI-G that more than convinces me that it works. I have a 24' tailerable boat with a hardly broken in 250hp Etec outboard. I wasn't able to use my boat for over five years due to health problems. I treated the 118 gals of gas with PRI-G over five years ago.
I wanted to take it out this year but all the experts said to first get rid of that old gas. I ignored their advice and decided to use the old treated 118 gallons of gas. When I started the engine it started before the starter turned a full rotation. We ran it for approx four hours in the bay and in the ocean at idle speed, trolling speed, full speed and in between speeds. We also stopped and started it several times. Not once did the engine hesitate, hiccup, skip, etc. We were amazed!
I have been using the PRI-G in my car, boat, yard tools and toys for some time and have never had a gas problem. I have also been using the PRI-D in my F350, 6.0 diesel with no fuel problems.
I just recently began to carry the Archoil products especially for their AR9100 oil additive but have not tried the AR6200 fuel additive. I'm hard pressed to switch fuel additives because of my and customers success with the PRI products.
Hope this long answer helps answer your questions.
Blue Spring mod
ScanGauge II
Up-idle mod
Zoodad
post #8 of 31 Old 09-13-2012, 08:31 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
I was just getting ready to start my own review of the Archoil AR9100, so I will just add to this one.
I just added it last weekend, but I noticed an instant improvement!!!
My truck has always started just fine with no issues, but ever since last winter it has been cutting out when I start driving after a cold start, once it gets to operating temp everything is perfect.
I did an oil change on Saturday and added the 16 ounce bottle of AR9100, then I only ran the truck for a couple of minutes to park it on the street. I didn't drive the truck until Monday morning for work, I figured it would take a couple days to notice any difference but was shocked when I first took off down the street because there was no cutting out at all!!!
My truck has been cutting out consistently every day for the last 6 months and now it has not cut out at all after adding the Archoil AR9100.
So it definitely gets a thumbs up from me
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #9 of 31 Old 10-18-2012, 07:32 AM
jimmyv13's Avatar
Quoted: 46 Post(s)
Feedback Score: 3 reviews
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
I added the 9100 in my last oil change after seeing positive results from Rev-X and I'm a little disappointed. I drove the truck after the change that day for about 50 miles and didn't notice anything different. The next morning and every cold start since then, it rolls to an idle instead of popping to start. Still the same crank time, 1-2 seconds. Warm or cool starts are normal, it pops after a 1-2 second crank. I'll be sending in a blackstone when I'm due for another change and I doubt I'll run the 9100 to see if it does the same thing w/o it.
2005 F250 CCSB Lariat FX4
4" MBRP Turbo Back*Sinister Coolant Filter*SRL+*'10 Tailgate*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*ARP's*'10 Tails*N-FAB Steps*'12 Rear Bumper*Dashboss*Pioneer DVD*'08 Trans Pan
*Bullitt y-pipe*'14 PE PF Mirrors*Fox 2.0 IFP*'08 Diff Cover
jimmyv13 is offline
post #10 of 31 Old 10-18-2012, 08:08 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Hmmm, well I guess it is different for each person. I am having great results running my AR9100. I plan to keep running it.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
