Turbo Boost Gauge Question - Ford Powerstroke Diesel Forum
Old 10-17-2007, 01:04 PM
Newbie question - I have decided to add pillar gauges to my 04 F250 6.0 PS. What exactly is the "Turbo Boost"? I noticed when ordering that particular gauge, I need to decide on 30 lbs, 40 lbs, or 60 lbs. I realize this is the measurement parameter but I have a stock truck that I recently added a performance chip to so everyone recommends gauges.
Also while we are on the topic, can someone point me to a thread that will tell me what temps, pyro (another ?), measurements I need to be looking for? I don't run the truck hard and only tow atv's to deer camp so nothing really heavy.
Old 10-17-2007, 01:06 PM
anything over 1200 back her down normal is around 6-8 for me. I would get a 60 you may never need it but if you do it is there. mine is a 1600 temp autometer NV. I love them check the vendors on here for the stuff and they hook you up
Old 10-17-2007, 01:13 PM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
The "Turbo Boost" gauge tells you the boost pressure above ambient pressure that the turbo is producing. I would go with the 40psi for now. Gauges are relatively cheap so you can upgrade if you need to down the road for $40-50. Your truck even with a HOT tune shouldn't hit higher than 31-32PSI.
General rule of thumb is to keep the EGT's below 1250-ish. It's OK to get 'em a little higher for a few seconds...but not for a long time. (Make sure you install the EGT probe PRE-Turbo. There are writeups everywhere about it.)
Thats Mr. Oil Leak.....
Might as well go with the 60 even if you never use it atleast you know you won't be pegging out with a smaller gauge.
as for pyro 1250 is the highest sustainable (sp?) temp you can run. anything higher you can run but not for long.
