High idle mod when motors cold - Ford Powerstroke Diesel Forum
Old 10-16-2007, 01:44 AM
I was wondering if its ok for me to turn my high idle on as soon as I start my truck for the first time in the morning my mod kicks the rpms to 1200 I didnt know if I should wait after starting it or not thanx.
Old 10-16-2007, 01:52 AM
DKR DKR is offline
<--Pro Cooler Racer
Dunno, I usually start it, then throw the switch.
Old 10-16-2007, 04:46 AM
I let it idle for a few seconds before hitting the AIC.
Old 10-17-2007, 05:21 AM
Send a message via AIM to dieselmatt
What is the advantage of the high idle?
Old 10-18-2007, 02:39 AM
prevents wet stacking,allows engine to idle up without being in the truck unlimted uses oh yah jump stating tractors. only costs $5 a (toggle switch) why not not do it the wires are already there
Old 10-18-2007, 03:11 AM
to tell you the truth, you could go to the wire direct. Then use the parking brake for your switch. At least thats how mine works.
Old 10-18-2007, 03:12 AM
As long as you give it time to get the oil pressure up, it shouldn't hurt anything. I usually wait like 30 seconds.
Old 10-19-2007, 12:49 PM
Ok Sorry guys but I am all about doing mods. Would someone tell me how to do this high idle thing. THANKS
Old 10-19-2007, 04:03 PM
I thought all 6.0L came with the high idle, mine idles up to 1000 or 1200 rpm when it gets down to like 30 deg.
Old 10-19-2007, 05:11 PM
there is a big difference between the factory cold idle, and the "high idle mod" that can be done. i believe it is more like 1800rpm.
and you would want to at least wait about 10-15 seconds to make sure the oil pressure is good and everything is lubricated.
