Boost gauge setup - Ford Powerstroke Diesel Forum
Old 10-15-2007, 04:27 AM
Boost gauge setup
Where do you hook up the hose to from the gauge? Is there a spot on the turbo that I am missing? I am sure it is something easy. Thanks for your help
Old 10-15-2007, 04:37 AM
Send a message via MSN to JoeyCleland
You can either:
A. Tap in to the map sensor tube with a 1/4 x 1/4 x 1/4 Hose barb T (Go get a brass one from the HW store, the ones that come in the kits are usually cheap and too small, Somebody will post a pic shortly im sure)
B. Do the Air Intake Heater removal and get the plug with the boost fitting. I think ITP diesel has them for cheap.
C. Drill and tap the intake manifold
Joey. PS WAR DAMN EAGLE!!!!
Old 10-15-2007, 04:42 AM
I just did one yesterday and i drilled and tapped a hole in the intake manifold.
Old 10-15-2007, 08:14 PM
i spliced a "T" into the hose running from the passenger side of intake manifold to the factory MAP sensor that hangs under the cowl by firewall. i will be drilling/tapping when i put the new manifold in next month.
Old 10-16-2007, 04:48 AM
i just did it through my accufab intake elbow
