Boost psi on looney tune - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-12-2012, 09:10 PM Thread Starter
Motorboy8769's Avatar
What are y'all seeing for Max psi on the looney? Not sure if I'm lower than normal I'm seeing between 20 - 24 ish. Where stock I would see 28
2004 f250, dual 5" chrome stacks 285/75/16 at 10 ply, Vivian's looney (awesome) duplicolor spray bed liner on my rockers and fender lip 10" high
2008 f-350 CCLB,
Rough country 4.5" radius arm drop lift
doc and Dpf delete
looney street from vivian
Motorboy8769 is offline
post #2 of 4 Old 08-12-2012, 09:43 PM
wngnt954's Avatar
I can hit 30-32 no problem.
The Family Truckster
wngnt954 is offline
post #3 of 4 Old 08-12-2012, 09:58 PM
mazsecond's Avatar
Feedback Score: 4 reviews
On just a WOT run I see around 25psi but if I'm crusing on the highway with the torque converter locked and I roll into the throttle it can hit low 30s easily. What kind of smoke are you getting at WOT? It should be a light haze, if your getting a lot of smoke wide opne then your not getting enough air (i would suspect a turbo problem) maybe sticking vanes You can always shoot Vivian an email, she is a joy to work with
Mike
mazsecond is offline
post #4 of 4 Old 08-13-2012, 05:01 AM
Quoted: 2 Post(s)
Exactly what mine does.
2006 F350
6.4 banjos
FP spring
Insight CTS
IDP/Looney SCT X3
Studded
Durastroked
S&B,CCV
FICM Repair/PHP 40hp
2008 F250 FX4
DPF-R +
06DZL is offline
