i dont wanna roll coal - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-11-2012, 05:37 PM Thread Starter
fatdoug's Avatar
So as the title says im going to tune my truck later this month but i don't want to be rolling coal like a cummins jack@$$. i haven't been able to find a thread about what tunes smoke the least. Im more than likely going with the X3 with unlimited tunes from Vivian. so my question to the guys running Vivians looney tune is how much "coal" am i going to be rolling? and which "performance" tune is the cleanest?
Regards
Doug
Black
2006(dec 05 build date)Reg cab Long Box 4X4 6SPD 6.
100,000 KM as of april 8 2012
3" lift
325's
blue-spring
Coolant filter
5" MBRP turbo-back straight pipe
harley buckets, centre console and gauge cluster
high idle
KCCO
fatdoug is offline
post #2 of 13 Old 08-11-2012, 05:58 PM
from my experience, a vxcf9 tune runs cleaner than a vxcf4 tune. with my FICM tuned (ID Moderate) and running a vxcf9nz ID Aggressive street tune the only time I get that to smoke is if I'm at a dead stop and just smash the skinny peddle but it clears up real quick. crusing say 55-60 and if I smash it I only get a small amount that clears up real quick. Now with a vxcf4ng aggressive street tune any time I roll into the throttle say through a curve and roll back into it then it's roll coal time. over all on the dyno if your FICM is tunes there not much power difference if at according to Eric@ ID.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #3 of 13 Old 08-11-2012, 06:06 PM
bondajb's Avatar
I am running vivians looney wild. Only smokes when you make it. vivian claims this is her most eficient tune if you drive it right. On the interstate if you give it too much pedal with the tc locked it will belche badly. You will learn what causes the smoke and is easy to correct. It is nice having power to spare when you need it. My tow tune she recomended the vxcf9 flash.
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #4 of 13 Old 08-11-2012, 06:16 PM
This is what I found with my vxcf4 or non inferred releases do that the vxcf9 inferred don't seem to do it or when they do it's not as bad. And for my setup (which won't be the same for everyone) the vxcf9's seem to have better cleaner throttle response.
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
post #5 of 13 Old 08-11-2012, 06:24 PM
bondajb's Avatar
I notice the same when I flashed. Even in stock form it was more resposive....less lag. Much smoother tuned expecially with looney wild.
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
bondajb is offline
post #6 of 13 Old 08-11-2012, 07:01 PM
pizalm's Avatar
My innovative street tune is pretty good. I have a 6 speed and it only smokes a ton of I'm lugging the engine and smash it.
pizalm is offline
post #7 of 13 Old 08-12-2012, 02:22 AM
I'm running non studded MPD right now and I can barley get it to smoke no matter how hard I punch it. Vivians tunes are awesome and my favorite still but they will roal coal
2004 F350 PSD
8" Icon, Loud Pipe, 58v FICM, Deleted, MudGrapplers, Edge Insight, Sct tuned by Vivian.
2011 F350 PSD
AFE , Airbags, Recon, BMF , Nitto,
20046.0 is offline
post #8 of 13 Old 08-12-2012, 03:21 AM
Try Gearhead automotive performance. Matt's SRL tune has good power without the light switch effect and is the least smoking tune that I have found.
Sent from my DROID RAZR using AutoGuide.com App
2012 F250 Lariat CCSB FX4, Gooseneck and 5th wheel prep package, H&S Minimaxx, 5" AFE SS straight pipe, EGR delete with factory EGT sensor, 35" Toyo MT's on stock rims, and Bilstein 5160 shocks.
thomaslord84 is offline
post #9 of 13 Old 08-12-2012, 03:08 PM Thread Starter
fatdoug's Avatar
thanks guys i appreciate the info. I'm still leaning towards vivians looney, but if i find it too obnoxious i will be trying the gearheads tune, and as lots of people seem to say some tunes work better on different trucks, I'm just hoping to find a clean running tune that both my truck and I like.
Regards
Doug
Black
3" lift
325's
blue-spring
Coolant filter
high idle
KCCO
fatdoug is offline
post #10 of 13 Old 08-12-2012, 03:20 PM
The looney does not smoke to bad on my truck. The looney wild, on the other hand, will blow some smoke.
Sent from my DROID RAZR using AutoGuide App
