Doing studs and stuck. - Ford Powerstroke Diesel Forum
Old 08-11-2012, 01:41 PM
Just rebuilt my oil cooler and put in the new pipe for my egr delete. How much more is it going to be to do studs one at a time? What more has to come out and how long should it take?Doing studs and stuck.-uploadfromtaptalk1344721261394.jpg easiest way to get the heater box out?
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 08-11-2012, 01:50 PM
Originally Posted by Stumppy View Post
Just rebuilt my oil cooler and put in the new pipe for my egr delete. How much more is it going to be to do studs one at a time? What more has to come out and how long should it take?Attachment 41709 easiest way to get the heater box out?
HOW TO - Step By Step Bulletproofing
that thead has pdf files that will show you whatever you need to know as fas as the heads studs. I would hihgly reccomend pulling the heads and having them checked though.
Old 08-11-2012, 01:54 PM
I dont have a blown headgasket and I am only thinking about doing them one at a time because I am already this far down in the motor. Ive heard of people doing them with out having to dump the ac out of their lines.
Old 08-11-2012, 03:47 PM
The heater box is held on by 5 gold nuts/washers located behind the glove box.
Old 08-11-2012, 03:48 PM
I've taken those off but the dang thing still won't slide out.
Old 08-11-2012, 04:05 PM
U need to drop the inner fender and the whole vacume system
Old 08-11-2012, 04:50 PM
Yep just got it thanks.
Old 08-11-2012, 05:36 PM
Not a problem
