Experienced Modders - What's Next?
I have an '07 6.0 crew cab lariat. Mods done already are:
-Egr delete -Cat delete -New oem oil cooler -Coolant filter -Studs -Head, intake, exhaust gaskets -Ficm checked and repaired/updated -Sct tuner w/custom tunes On the to-do list: -Edge insight w/ pyro & fuel pressure -4" exhaust My question is...what's next? Upgraded turbo? New injectors? New fuel system? What else? And in what order do you recommend?? |
What is your power level goal?
Write Up: Power Potential of the 6.0L PSD Start with the monitoring plans and exhaust first. Depending on how much power you want to make, will determine where I recommend you going next. |
I'm not sure, really. Maybe 500hp, 1000tq. I want lots of it available at the low end, doing city driving. And I want good, refined highway driving.
This is more of just an information gathering thing for me. I like organization and lists lol. My next upgrades, theoretically, would be something like: 1. Cold air 2. Stage 2 turbo 3. 175 or 190 injectors. But maybe I'm way off. And maybe all that stuff wouldn't work well with the parts I'm leaving stock? |
Not too far off.
--For CAI, I recommend the S&B with those injectors and turbo. I like the stock unit, but feel you'd be really holding that build back. To break the 500RWHP, all you would need for injectors is 155s with either a Hybrid, or a Stage 2 turbo. This would also have a decent streetable level of power, without the need to work on the transmission other than tuning. With the larger injectors, you'll be anywhere from 550-650+ RWHP depending on turbo and supporting modifications. --Either set of injectors is going to require an aftermarket fuel system. I'd recommend a RR, and aftermarket pump at least, a sump may help as well depending on pump. --With the 175's the Stage 2 should match well (actually Adrian will be testing his 175/75s with the Hybrid, Stage 2, and Stage 3 shortly at TSD and work out tuning.) --With the 190's the Stage 3 or 4 would be a better match than the Stage 2 (Nate will be testing his 190/100s with the Stage 2, and Stage 3 shortly at TSD and work out tuning.) *It may be best to await those results for this build* Each build ends up with a different attitude. Hope this helps. |
once you get an exhaust thats a very nice 500+ list. very driveable and pretty quick
So after my exhaust and gauges...if I do a cai, stage 2 turbo, 175 injectors, and a fuel system...I should be pretty much done without requiring tranny work? Should I do a blue spring mod as preventative maintenance? Or is that a "if it ain't broke" thing? |
Thanks. Hopefully that's what I get in the end. And to think this truck was bone stock only 4 weeks ago lol.
I would say that your list, is a great starting point for your build. As for the fuel spring, its not a bad idea for the cost. I haven't done so yet, but I don't have any issue with my fuel pressure. Its your call, but I would monitor fuel pressure via the Insight very close, if you have low pressure knock it out. This choice also plays a factor into how you go about installing an aftermarket fuel system, as some remove the stock regulator completely. |
Sounds great to me. Thanks for all the info! |
For your build, you are definitely on the right track. So far, theoretically anyways and provided the tuning can be dialed in, I would recommend the MTW Stage 2 with 175/75s. This should put you in the 550 range and with sensible driving, your tranny should hold up pretty well as well but like Ben said, wait for the tuning for right now. JMO.
