Intake manifold options - Ford Powerstroke Diesel Forum
post #1 of 82 Old 08-05-2012, 09:19 PM Thread Starter
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
I know that go-go has there intake manifold with all the egr deleted, for $1200 and Adrian won't make em for anyone else:, i saw one the other night but wasn't as modified as I wanted it to be. so where else can i find one with the inside gutted, ported, polished, and all egr stuff removed??? Or what other options does a drive way tinkerer have?
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
post #2 of 82 Old 08-05-2012, 09:44 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Absolute Performance and Holderdown Performance can both supply what you want. I will be putting on a stage 3 that is done by Matt aka sootpowered and available through Holderdown. I believe Elite sells one also.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 82 Old 08-05-2012, 09:47 PM
The Silent Service
colo_dually's Avatar
Quoted: 31 Post(s)
You have three aftermarket units that I know of:
1) Go-Go, which may be a bad choice based on the reviews I've seen on the little gaskets leaking, and some owners having to torque the manifold to fit, since it showed up warped.
2) Absolute Apex, Absolute 6.0L Apex Intake Manifold - These also bolt on the floor and then get plugs on top.
3) Soot-Powered [Holderdown], Got the soot powered high velocity intake manifold!!! - Looks like it bolts like the stock manifold.
All run about the same when you look at their sites. Some of the forum prices are less.
You saw what Adrian is doing by hand with a grinder, if you can do the welding yourself (or cheaply) that may be the best option of all. I like the diverter on the Soot-Powered unit, may incorporate that into mine (should I take the job on myself).
On Edit: Looks like he beat me to it.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #4 of 82 Old 08-05-2012, 09:48 PM Thread Starter
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
Thanks Mitch i'll check em out, i dont think elites has the egr delete, that was the one i saw the other night. Hows the truck going?
Sent from my P. O. S. fone
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #5 of 82 Old 08-05-2012, 10:00 PM Thread Starter
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
Thanks Ben good food for thought
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #6 of 82 Old 08-05-2012, 11:07 PM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
You can buy a good stock intake manifold on eBay right now for $85 plus shipping that's what I'm doing when I rip mine apart for studs and gaskets. I'm cutting the enitire manifold in half and gutting it completely polishing the entire inside and filling the voids adding a diverter deleting the egr portion porting the ports and welding it all back together.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 82 Old 08-06-2012, 10:22 AM
Just finished this one...its completely gutted of the egr stuff but the coolant can still flow like stock. I read on a couple forums that the egr deleted intakes that ran the coolant back to the bottle were experiencing warmer oil temps so i wanted to see how this would work. Its ugly but the next one i do will be made with custom tubing for the coolant instead of the stock neck, just ran outa time on this one.
Sent from my DROID4 using AutoGuide.Com Free App
ID:	41422   Click image for larger version
yetti1996 is offline
post #8 of 82 Old 08-06-2012, 12:52 PM Thread Starter
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
There is a hell of a lot of pissing going on over these things. seems like best bet is to go at it yourself, when I get my garage up this will be the first project going down in there. Thanks for all the info. I'll do a thread of cutting one apart in a month or so, then you guys can all tell me where I'm going wrong
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
post #9 of 82 Old 08-06-2012, 01:13 PM
The Silent Service
Quoted: 31 Post(s)
Keep us posted.
post #10 of 82 Old 08-06-2012, 01:19 PM Thread Starter
sealeveloc's Avatar
Quoted: 21 Post(s)
Garage
just double checking 03-07 are all the same correct
Byron
O6 350 XL
maybe a lil more,
maybe a lil less
