turbo advice needed - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-01-2012, 07:20 PM Thread Starter
turbo advice needed
Im having a hard time keeping my egt's down, I can keep them down if I really ease into the throttle and watch the boost but if I mash the pedal off a stop I only build 20# of boost and the egt's go up super quick. Ive got an edge cs race installed and 4" turbo back exhaust, w/o a muffler or a cat.(It has a really nice bark) I can hit 29#s if I roll into it easy, so I dont think I have an air leak. Do I need to clean my stock vgt? Is some back pressure needed to make the stock turbo build boost correctly? Or do I go to a conventional turbo? I'm running the stock air intake and filter, I dont think that's the issue though. Im running the programmer in lvl 3 currently but can get the egt's up in econo and towhaul too.(it just takes a bit longer).
Edge CS Race, MBRP 4" turbo back no muffler or cat 35" procomp extreem at's w/o a lift. Saving my $$$ for more goodies.
bigoneton is offline
post #2 of 12 Old 08-01-2012, 07:27 PM
Joeshu1000's Avatar
How much boost can you make when it's stock?
Joe
2006 F350 XLT CrewCab 4X4
325/65R18
EGR Delete
Zoodad Mod
High-Idle Mod
Sinister Coolant Filter
ARP Head Studs W/ OEM Gaskets (Installed myself)
Upgraded Fuel Spring
Updated STC Fitting
Updated Oil Cooler Screen
Updated Dummy Plugs/Standpipes
6.4L Banjo Bolts
PHP Ficm Tuner
1/4 Mile 14.2 @ 93MPH
SCT Custom Tunes: MKM, Looney, SRL, SRLXX, Wildman and SPD w/ Early Lock up
Joeshu1000 is offline
post #3 of 12 Old 08-01-2012, 07:28 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I would ditch the Edge for tuning and just turn it to level 0 or stock and use it only for gauges and get a SCT custom tune. I would try this before I went the turbo route. JMO.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 12 Old 08-02-2012, 02:21 AM
What are you considering high EGT's? Your egts can get high on hard acceleration (1500* on a race tune), the key is not to hold them there for a long period of time. That is when you can cause damage.
2003 F250 4x4 SCSB lariat 6.0L auto, 4" lift, 35" nittos, sct tuner with custom tunes from IDP and TSD, S&B intake, blue fuel spring upgrade, fass fuel system, fs2500 oil filtration system, arp head studs, egr valve turned off, Egr cooler delete, power max turbo, bd exhaust brake, 4" stainless steel dual exhaust, gogo shift solenoid, ats deep trans pan, mag hytec diff covers, isspro gauges, cfm intake elbow
Nazty 4x4 is offline
post #5 of 12 Old 08-02-2012, 04:51 AM Thread Starter
ive seen 1700+ for egts, Ive never let it stay over 1400 for more than a few seconds though.
post #6 of 12 Old 08-02-2012, 04:52 AM Thread Starter
I could make 29# boost w/ stock programming too
post #7 of 12 Old 08-02-2012, 04:54 AM Thread Starter
any one know where i can get a good deal on a sct and a s&b intake?
post #8 of 12 Old 08-02-2012, 05:51 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Check your local Craig's list, eBay and on this site in the "for sale" section. I've seen SCT's as low as $100.
What to look for when buying used SCT for 6.0
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #9 of 12 Old 08-02-2012, 07:34 AM
I've used my edge cts tuning with no adverse effects and I've seen boost of 32psi on stock turbo when I hooked to the sled using that tuner but not the high EGTs that you're reporting here. My boost is a tad high so I may have an issue somewhere but EGTs isnt one of them. That being said the sct custom tunes are great but I don't think it's really a tuning issue? But I'm no expert on tuning I would try cleaning your turbo which really can't hurt anything it's just kind of a pain in the rear but I need to clean mine as well!
"the C4 6.0" 2004 F350 srw lariat CC
ARP's, Liberator fire ringed heads, EGR delete, Brute Force CAI, 6.4 banjos, blue spring, cfm+, Livewire TS custom tune, 5"turbo back with 4" down pipe. Cowel Hood. Lifted on 35's. Suncoast tranny. Newly added 05 grill and harley headlights.
Amfw119 is offline
post #10 of 12 Old 08-02-2012, 07:43 AM
DSTRBD's Avatar
Yes, check our site or give us a holler.
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
