Originally Posted by champelite210
Just got mine and was fulling around with it before i do the final instal because i'm waiting on the thermocoupler. While going thru the pid's i noticed there wasn't a EGT option. Is this because the unit doesn't recognize it as an option until you plug one in or did i miss something. BTW I had it plugged into the truck setting up the screen.
Exactly. Plug it in after the EGT install is done. Turn the truck on and boot up the insight. Turn the truck off then go hook it up to the computer and open up mystyle and you should see where you can edit it.
-Guy
